I recently purchased one of those remote meters. I purchased the SwitchBot Smart Plug Mini W1901401. It can basically turn on/off any appliance that you want, and it tells you how many watts an appliances uses in real time and its history.
I have never had much luck turning the charging on and off with the Honda app, but this little device has worked well for me.
Initially, I was not believing what it was telling me as far as how much juice it was taking me to go from 2 bars of battery all the way to full. I then tried it with a kilowat meter, and I got the same amount.
Using different meters, it is taking around 9.75 kwHrs to go from 0.0 ev miles (2 bars,) to full such that the car will not take any more juice. This is when it says 100% on the Honda app. My car sucks an average of 1284 watts when charging via 120V. i only charge via 120V.
With a 14 kwHr battery, perhaps they are using a 15% cushion on the low side and the high side as far as battery capacity and how much they let you charge the car.
Has anyone else tested to see how many kwhrs their car is taking to fully charge? I am charging in 60-75F weather, day or night.
Side note: I did a search on the forum and I ran across one of my old posts from 2019. "According to my kilowatt meter on a 120V outlet with a 50' cord that is 12 gauge, I used 14.3kW hrs to charge my car on Friday (the only time that I measured it.) It seemed a little high even on 120V."
14.3 in 2019 and 9.75 now in 2023???
I am going to have to get another meter to make sure that I am measuring correctly. Although, like I said, I did run 2 meters independent of each other and I got the same 9.75kwHr number on 2 different days going from 2 bars of 0.0 ev miles to full.
