polyphonic
2800 miles.. 6/32 fronts, 8/32 backs. I might be having too much fun..
On the positive side, they are wearing evenly from inside to out.
I'm curious about how much wear those numbers represent. Do you know the thickness of the pads when new? Do you use the brake pedal often? I don't.And for completeness, brakes: front 11mm, rear 9mm
I consider it a failure if I touch my brake pedal, but the traction control uses the brakes whenever it decides to. Inspection technician said should be replaced at 3mm. I think they must be 12mm when new?I'm curious about how much wear those numbers represent. Do you know the thickness of the pads when new? Do you use the brake pedal often? I don't.
killing my stock fronts ATM. Waiting for the new wheels and I will have 225/18 tires on soon, so they will fare better! lol
