HondaCare on 2018 expiring
  • Thread starter Thread starter JKroll
  • Replies Replies 6
  • Views Views 454
JKroll
Is there anything I can proactively get fixed using this warranty?
What are the typical things covered and need to be checked ... car has about 92k
No. Honda Care will only fix what has failed. It doesn’t cover routine maintenance, preventative maintenance or normal wear and tear.
Read the policy. If you believe that you have a claim, take care of it prior to the expiration date.
It seems that the warranty replacement limit is 36.6
I can ask them to check the battery ELM to see if my HondaCare will cover this. Not sure what my battery ELM is currently.
The traction battery and many other components are covered under a Federal Emissions Warranty for up to 10 years or 150K miles. Expect the dealer to charge a diagnostic fee if you request a battery capacity reading. Not sure what they charge to check the ELM.
You initially asked about what could be fixed proactively under the Honda Care contract and I attempted to explain to you that nothing would be fixed under warranty that hasn’t failed. You have a misunderstanding of the contract.
No I dont have misunderstanding of the contract. There are things which have failed that I dont know about. If they check for it they may discover it
