I think I may have a clue to my map problem. Can someone please check to see if their Clarity Navigation myMaps page (after the map update a few months ago) has three maps, or just the two in my post above. If three, a screen shot would be much appreciated. Thanks very much!!
Thanks very much Ken! You just confirmed my suspicions.
I believe that I lost a map (the one that contains all the detail on local roads) in the update I did in Feb. I'll try to do another update to see if it can be recovered.
Are there instructions on how to update the maps with the car? (Haven't received mine yet.) I used to have a Garmin GPS with lifetime map updates so I'm somewhat familiar with the process, but it must be OTA unless there is an SD card. Are the map updates free for lifetime?
Awesome, thanks! My Sonata has an SD card and apparently has to be updated at the dealership, so I haven't bothered in the 2 years I have had it. This will be much easier to do it myself.
Since the car has to be running the whole time the update is processing, can the car be running while still plugged in? Sorry if that seems like a dumb question.
Yes - the link above by iluvscuba leads to a fairly simple 1 page instruction sheet. You will need a 16GB or larger USB thumb drive as stated in the instructions. It is not difficult, BUT I now need to make sure that my update was not the action that resulted in me now missing a KEY map. Hence, I will try to update again this week, hoping to recover that map.
iluvscuba: You will love this car! I got mine on 12/30/17. I can't get over how much it does and how nicely it is equipped. There are only a few things missing, such as the cross traffic alert system. I am assuming that my map problem was somehow of my own making. Cheers,
thanks Ken, but I have already downloaded the pdf, just never open it as I want to wait until I am close to getting the car. I will probably drive me nuts if I read the pdf and can't play with the car...
There is so much to read in the Owners Manual that you should get started now, before you start spending all your time in your car. As you're reading, make a list of the stuff you want to play with. Really.
I did some checks over the weekend with other Clarity (Thanks KentucyKen!!) and CRV owners. They had all 3 maps under myMaps, while I had only two. That was a key clue!
I reapplied my previous map update already downloaded on my USB memory stick in Feb. (without going back to the Garmin Express map down-loader.) I now have 3 maps showing in myMaps and the missing detail is no longer missing.
My guess is that my previous update was downloaded OK from Honda/Garmin to my USB stick, but did not properly install all 3 maps in my car. That may have been due to my error.
