Atul Thakkar
I am in Canada and we have a cold weather for a longer time than normal , so I was wondering is there a possibility to turn on heater such that it runs on gas rather than battery while you are driving ?
Interesting discussion guys. I get that the PHEV has a resistance heater that heats the coolant to heat the cabin. Is it also true that if you're running the ICE, like on a road trip in HV, that the heat comes from the ICE's waste heat (like in regular cars) and not from the resistance heater?
Thanks Viking79. Coolant temps are always monitored by a thermostat so I imagine it's just some lines of code for the computer to turn off the resistance heater if the coolant is already hot from the ICE.The waste heat from the engine is definitely used. I am unsure about the electric heater usage. My Volt can control electric heater separately, and if both are on, they are blended. I am unsure if Clarity is similar, but they do share the same heater core. My hunch is the electric heater is either disabled, or only heats the difference between the requested temperature and the coolant.
