Casey Martin
I have a 2018 Clarity PI with over 130k miles. I have changed the rotors and pads a few times but I have a new problem that has started recently. Intermittently the front left brake caliper will hang up causing a bad vibration above 40 mph. Usually a few hard slam on the brakes will get it to release. This has only happened a few times over the last month or so but it happened again this morning. This time it remained hung up for a lot longer than it had previously. I think it is time to replace the left front caliper before it locks up completely.
That leads me to the point of this post. The front calipers for the Clarity are unique to the Clarity. They are not used on any other Honda. Needless to say they aren't cheap. I work for a Honda dealer and my employee cost is still over $300. It will also take about a week to receive it. I checked on Rockauto for an aftermarket option and they are out of stock. I did click to be notified when they are available but I assume that might never happen. I couldn't find any other aftermarket options anywhere else as well. It is looking like my only option is to purchase a new Honda caliper. I know it is possible to rebuild a brake caliper but I know that is not commonly done anymore.
If you had to replace one of the front calipers on your Clarity what did you replace it with?
