No. What I've noticed is that if I'm heading home and I know I'll be close to home, I will then I allow my car to go to 0 EV range. Very consistently, within a 1/4 mile of the guess-o-meter displaying 0, the gas engine kicks on. That's why I tend to believe the EV estimate. i.e. for my driving pattern its been pretty accurate. I also do the feature where I have my A trip meter set to reset each time I charge the car. I know my distance to/from work is 5 miles (almost exactly) so if I do 4 legs of 5 miles each I hit 20 miles or often barely exceed it.
If one looks in the HondaLink app you can see a numeric representation of the EV range left. When you see 0 on the dash and 2 bars, the percentage is maybe 7-10%. We know there is a buffer. So I make sure there's enough in the buffer to get home and plug in, without ever tempting a true 0%. We see the EV bars go to one when this percentage goes below 5%. Some Clarity owners never see that, but its easy to do in my car if one is not careful.
Anyway, the reason I stress the 'hill' is that in my experience, and for my usage, it outweighs every other factor for EV range. We all know and been discussed at length that say using cabin heat kills EV range. No argument with that, its just that I don't lose 10 or more miles of EV range by using the cabin heater.
One last thing as it may benefit others: I think the folks who have repeatedly run the car with too little EV are the ones that experience the rare condition of losing power (i.e. on the freeway) which can be dangerous. It's a rare outcome, but I'd bet the folks who see this repeatedly ignored lots of "angry bees" and low EV range.
As to why some folks don't see some of these issues with low EV range, unrelated to the hill, I think the traction battery gets damaged sitting on dealer lots for months with no charge. That was my Clarity's case. I suspect there is a correlation between the cars that sat for months with no charge, and the cars that don't get the best EV range (estimated or actual).
When using a volt meter to test batteries you can notice a bad battery in some cases with low voltage, but in others you have to measure with resistance to see a problem. Maybe in some similar way the amp hour reading doesn't tell the whole story. My amp hour reading is similar to other Clarities of its age, last tested at about 48ah, but I don't see as good of EV range as some others on the forum. So there may be multiple factors.
