David Yuan
Is there a way to always use green mode instead of mid on startup?
thanks!
thanks!
Ahhhh, that reminded me, I moved my coding setup from the i3 to the mini, and it just worked : )
That OBD device has been in the i3 port for the past 3 years I think...
I was able to set "eco pro" as the default (green equivalent).
thanks!
I'll be interested to read about what this app can do with the MINI Cooper SE. Before my SE went to the body shop for its scoopless hood installation, I didn't get around to trying to access the hidden menu found on the BMW i3.Yeah, I expect https://bimmercode.app would be able to do that.
Nice. So you can select what mode it starts in? Does the dongle need to stay plugged in or does it change a setting in the ecu?Ahhhh, that reminded me, I moved my coding setup from the i3 to the mini, and it just worked : )
thanks!
