So for a while I suspected that the GOM algorithm was faulty, and now I think I have cracked it. I went up the coast last weekend - 120ish km of freeway driving. There was a few roadworks where the speed lowered to 80kph, which helped the economy. I kept a reasonably careful eye on the consumption which was around 14.5kWh/100km. When I got home and recharged, the GOM read 190km - acually the largest reading I have ever seen. My theory is that the GOM only takes into account the energy *used*, not the energy regenerated. A freeway trip regens very little, so you use close to your average consumption. Around town, you regen significantly more, but also use significantly more (always accelerating, slowing etc).
So on the freeway, I used 14.5ish, which translates to around 200km range - 190 is pretty close. Around town, your consumption may be around 18kWh/100km *but*you regen say 6 kWh/100km. Total use from the battery is actuallyon 12kWh/100km. 150km on the GOM translates to around 19kWh100km. Yep, it fits. In the real world, regen is a thing so you may use 19kWh/100km, but you get back say 7kWh/100km, giving a net of 12. This gives around 240km range. Yep, it all fits. I suppose you can't guarantee regen, but you can be quite certain of the used power. When I say used, I mean the power drawn from the battery rather than total drained from the battery (drawn - regen)).
Anyone driving around town with lots of regen will obliterate the GOM, whereas a freeway traveller might get a reasonably accurate figure.
