Obviously there has been a lot brought up about this, especially concerning the change intervals.
I would like to add in conjunction with particle effects there is a more common form of contamination and performance reduction that being high humidity.
Thanks to VW Technician @ ID4 forum
"EV propulsion units are completely different than, ICE transmission.
It is more similar to the RWD differential, with some different parts like..... bearings ( balls are ceramic coated or use special non conducive metals to prevent arcing from eddy currents), slightly different oil chemistry that is tailored for electric propulsion units ( low conductivity).
One thing that will affect oil in this type of propulsion units are humidity ( it will cause acidity with time if vehicle was constantly used for short periods of time in high humidity or big temperature swings)."
Further couple of documents:
"Locations with high humidity or high altitudes can create unique problems for shaft mount reducers. Humidity causes condensation – even within a well-sealed gear reducer. When condensation (water) gets into your oil, it doesn’t work as well. To combat humidity, inspect the lubricant often and change it if necessary."
Also:
"Humid environments, or applications that see wide temperature swings, can cause condensation inside of your gear reducer, adding water to the oil. Any contamination will decrease the effectiveness of your oil. It’s important to check the quality regularly and change the oil if it’s contaminated."
I only brought this up to make owners aware that living in a high humidity environment is another good reason to replace the GRU oil before the indicated interval. I don't believe anyone has posted water contamination levels analyzed to this point.
Also:
