Ray B
I respect you for respecting their copyright and I thank you for spending the $28 to read the remaining pages so you could tell us they didn't reveal any essential information.
Here's a breakdown of the sections after page 5:
- further description of the IPU layout and wiring
- battery dimensions and cell specifications (no mention of chemistry, which is something I was hoping for)
- IPU heat management - includes a description of the bypass circuit that extends the battery life by ~15% (when the cooling circuit is working on cooling the power components like the DC-DC converter, it will bypass the battery if it is already cooler than the coolant in order to avoid adding heat to it and degrading the life)
- A section on the PCU - includes a PCU specifications table, PCU circuit diagram, VCU waveform diagram (neither are easy to interpret with the text that was given), and a simplistic chart of the improvement in power density over the previous PHEV design
- Conclusions
- References
One thing I found illuminating was the description of the EV battery life extension by using the cooling bypass circuit. It showed a chart of battery capacity vs years (no units on either axis). Clearly it was likely the output of a model, and there was a regular dip/plateau for the curves that eventually depleted it past the "end of life criteria" line near the bottom. When I say plateau, I mean the curve was still going down, but the slope of the line was mild, and for the dip, it was about 3X the negative slope of the plateaus but for a shorter period. The dips in battery life were more extreme in the early life of the battery and very limited by the end of the life.
My assumption is that the plateaus were associated with fall/winter/spring conditions and the dips where most battery degradation was happening was the summertime. I concluded that because the whole discussion in that section was about excess heat degrading the battery life and how the bypass circuit helps. Again, this had to have been a model of life degradation.
Anyway, that was the only thing of value that I could glean from the final 6 pages. If you are someone with an interest in electric circuits and the like, then you may get something out of the PCU section.
