Fast Eddie B
OK. I'll stipulate fraud is a strong word. But consider this...
The car knows exactly how far you've traveled, and I assume it knows exactly how much fuel its burned over any given distance. So calculating average mpg exactly over any given trip should be trivially easy.
And yet, we just took a trip to Florida and back and kept careful records of the 7 tanks of gas burned. More on the trip in a dedicated post to follow, but it revealed that the car consistently overestimates gas mileage:
The left column is the actual mpg from dividing distance traveled by gals consumed. The "Est" number is what the display in front of the driver showed before resetting Trip A. As an aside, over the entire trip the EV range dropped 24 miles (from 44 to 20) in spite of being in HV mode the entire trip, but I'm not clear how to factor that in.
I'm generally not a conspiracy theorist, but can anyone think of an explanation other than Honda made a conscious decision to pad the mpg to make the Clarity seem more fuel efficient than it actually is? It really seems like they wrote an algorithm to calculate gas mileage, and then added about a +12% multiplier to it.
Thoughts or other theories/explanations? And has anyone else run a similar trial? In any case, it seems like Honda and/or some consumer advocacy group should be made aware of this.
My working assumption is that Honda is not alone on doing this, but it still seems wrong.
