Surprised noone else mentioned it... have you verified your climate control is set to Fresh instead of Recirculate? Checked to make sure no leaves/debris is clogging the intakes near the wipers?
That’s the important clue. I bet you have a light coating of the plasticizer that off-gasses from the dash and rear deck on the inside of the front/rear glass. Moisture is attracted to the film and fogs up the glass. Use a good glass cleaner generously and clean the glass twice. I like the 303 cleaner (not the protectant).Everything is clean. I tried both settings and no change It's weird because only the front and rear windshields fog up not the doors.
I have noticed the exact same thing occasionally. It shows up particularly on really cool days when it is drizzling or raining. The last time it happened the front and rear windows were noticeably more fogged up than the surrounding cars. It was almost opaque from the outside, except for the outline of the rear view mirror and camera.
It appears to be it is mostly because of the aerodynamics of the car and the shallow angle of both of those windows. You are looking through a grazing angle of the glass so more of the fogged up droplets on the glass fall within the field of view. Same reason why on average there seem to be more clouds along the horizon than overhead. The windows on the door are more vertical.
This is consistent with the issue of fogging up due to apparent volatiles on the rear glass that is sometimes discussed here. I doubt that the material used in this car is particularly different or more volatile. But any effect of material settling on the glass and condensation on it likely appears worse because of the shallow angle of the aerodynamically optimized glass surface.[/QUOT
I have also noticed my Clarity fogs up more than any car I have ever driven. This explanation is brilliant.
I have noticed it here in Florida with the high humidity and the A/C is always on.Hey all?
I noticed that my claritys windows fog up a lot ! More than any other car I've had.
Anyone have this problem and if so does anyone know how to make it stop.
Thanks.
You have to lower the temperature to Lo also, right? Otherwise the heater will work hard using lots of battery, way more than the AC would. When I tried this, often times outside is just too cold, and sometimes I do precondition so I like to keep it at 70F.Nikko508- yes, sorry didn't mean to leave that out. Press the big Climate button. Manually press the AC OFF- then Select the furthest rightmost option that shows vents and feet.
I haven't verified this piece: I think if you simply re-start the system by pressing the big on/off button, and *not* ever pressing FRONT, I think it keeps. Also it may also keep things fine without AC if you start the system by pressing fan up/down. i.e. avoid pressing FRONT for subsequent re-starts.
And yep it saves power (helps EV range) but the AC on of course does help remove moisture and it does defrost faster when you need it. I was really excited at first because I found with AC OFF, I could simply turn up the temperature, say to 74 and turn on blower and still get the windshield defrosted. As our Fall has progressed and we're getting really heavy and persistent rain, I'm not able to avoid keeping AC on. I mean in a practical sense, my most important need is being able to see, and when it's really, really, wet here, I seem to need everything the system has just to see, including blower on max, AC on, heat on, etc. Also I do realize this also has to do with one's patience. If you leave AC off, but let blower run long enough you'll likely do OK, but I normally don't have a several minutes to wait before each drive (or I'm simply not that patient).
One last thing- my other car is a 2004 Tundra, way up off the ground. Love it on the interstate with lots of rain. My old Subaru Outback was also higher off the ground, and visibility was much better than Clarity. Clarity is awesome car, but in winter, being really low to the ground means visibility on the highway takes a big hit. Way worse than any truck or mini-van. You're simply lower to the spray from other vehicles-- 'Dishwasher' effect. Anyway, it makes me feel like I need the clearest possible view given that I don't have the luxury of being higher off the ground.
(if you are catching everyone elses spray directly, tolerance of even a little window 'fog' isn't there).
