AndysComputer
Bucee’s in Texas said they are going to install chargers which makes sense as their gas stations are destinations in themselves with plenty of shopping and great food options. Perfect for EVs.
CBS Sunday Morning recently did a piece on Buc-ee's. It's quite a phenomenon and a perfect place for charging an EV.Bucee’s in Texas said they are going to install chargers which makes sense as their gas stations are destinations in themselves with plenty of shopping and great food options. Perfect for EVs.
Not on site, but given Tesla's tech savvy I do not doubt every supercharger is remotely monitored in real time.
That I didn’t know!For Tesla's so far!
That I didn’t know!
then again, with Tesla being 70-80% of the EVs on the road I guess I can see their rationale…
I just had my second EA experience and it went well.
I drove 115 miles from Plano to Waco in Green mode (left with 100% and arrived with 15%).
In theory I needed 85% to arrive home with zero but I like a buffer and I suspected I would use more on the way back so charged to 97% (intended 95 but got distracted) and got back home on 7% but that was helped by very slow commuter traffic from Dallas to Plano. Without that I think it needs 95% worth of charge to make it at 70.
I too had looked at the route to Houston and thought it was not doable without the long way round route you describe, but between Ennis and Madisonville is 111 miles so given my experience today if you keep at 65-70 it may be doable as long as it isn’t too hot or cold.
Plus as you get to Buffalo if the math isn’t working you could switch to the parallel frontage road at slower speed to make it maybe?
I might try it one day if I’m feeling brave…
Also from the DFW area, I decided to drive to what I am guessing is the same EA location you mention (in Denton), and as a first-time DC fast-charge effort see what is what there, and try it out. However, my MINI SE was still above SoC of 80% upon arrival, so although there were plenty of open charging lanes I just looked it over without trying to charge there and opted to press on to our planned ultimate destination in Oklahoma, just across the Red River.
Once there, I visited a PlugShare-listed fast charger offered by an Oklahoma company, Francis Energy. There I plugged in my SE with the DC combo plug, swiped my credit card and proceeded to easily and successfully charge the MINI at 47 kW for 25 minutes. If this can be done in the middle of nowhere in southern Oklahoma by a local company, surely EA could easily be as reliable and successful as the local company in Oklahoma. But, based on your post and other reports, I guess that is not the case.
Rather than tell you I can show you:
I try and travel with the majority of traffic up to the posted limit. If ppl in the left hand lane want to go 20 over thats up to them.
But if I am in the middle lane in a 70 and the person in front is doing 65 and so are cars behind me then I'll stick at 65 with them.
Green mode largely just numbs the throttle so you are more efficient by the car ignoring small unintended movements of the accelerator pedal. Makes it easier to be smoother and more efficient. You don't need sharp throttle response on long highway runs.
Bear in mind I used more energy on the return journey, so would probably do Waco -> Ennis -> Plano instead of Waco ->Plano
Just do the math as you travel along and you should be able to spot if you are not going to make it and slow down 5mph. The earlier in the leg you slow down the less you need to slow down as the energy saving starts earlier. If you don't realize until later you may have to slow down 15 mph which I'd rather not. And keep doing the math, you may find you can speed up again by 5mph later.
It's all about energy management...
For me, I find that 210wh/mile in ABRP gives me a more realistic estimation vs their 265 or whatever. But I haven;'t tried it in really hot weather, maybe 225 would be better, not sure...
Also, I would zoom in on the route and see if you can bail out and follow a frontage road alongside the freeway if you need to as doing that at 55mph is safer than 55 on the freeway.
Yes that's correct they use Windows and can be hacked. EA tech support use TeamViewer to remote access the terminal.All four units were available (the site has two CCS/CHAdeMO pumps, a double CCS 150, and a double CCS 350). The CCS 150 unit I used last week decided to BSOD when I plugged in (Signet V2s use “Windows SE”??) so I moved over to the 350. The first dispenser cable didn’t lock on, and the screen kept telling me to unplug. I was parked diagonally (it's a barely used station during the week), so I grabbed the other cable and proceeded to charge like normal. Sheesh.
