Fall and tire pressure
I recently re-inflated my tires to my desired pressure (42 psi front, 39 psi rear), they had dropped by almost 10 psi (still around 32 psi). I immediately saw a 2%-5% increase in range, so I really need to keep a closer eye on it.
I just watched a video on how the pressures suggested on the tag inside the door of your vehicle is usually a lot less than what is best for mileage and tires. I have since upped mine. It makes sense if you've ever ridden a bicycle with low tires. It is much harder to pedal.
