Imagine if, in a few years, we could replace the SE batteries for under $10K and get an extra hundred miles of range.
Right on, @Newkirk!On the flip side, going back to the durability of the electric motor, if you can occasionally swap out your batteries for a technology upgrade, would you really need to replace the whole vehicle assuming everything's in great condition? Imagine if, in a few years, we could replace the SE batteries for under $10K and get an extra hundred miles of range.
It depends.
What is the car worth at the time of battery replacement vs battery cost?
What will insurance pay you the next day if it is totaled in an accident?
Will the old battery format (18650 vs 21700 for example) accommodate the new battery format 10 years later?
MINIs, including ICE models, already go through a calibration when the 12V battery is changed, so I'd suspect something similar would definitely be required to change the high voltage battery pack. There are companies (one in China and one in California) working on battery-swapping "recharge" stations, so the potential exists.There's definitely a lot more complexity than just swapping the battery (CAN communication with the car's computer for SoC info and BMS would be one potential issue)
MINI may not have an incentive to support upgrades for existing cars, though, if it means they'll sell fewer new ones.
That looks so similar to my setup, it's very nice. And I think almost all EVSEs are boxes mounted on walls, I think I only saw one flush-mount and it was super-expensive. I guess you could do it yourself by cutting into the drywall, but then it becomes difficult to service the EVSE or replace it.I ended up printing myself a custom holster/cable hanger because the one that came with the Grizzl-e felt a bit sloppy to me.
I purchased a 3-D printed holster for my charging handle. Yours is much nicer.I guess by flush I meant the box would be against the wall rather than floating an inch or so away due to the aluminum mounting bracket.
If it was mounted somewhere else in the garage where you'd typically walk or get in/out of the car, that extra inch or so sticking out would be more of an issue but with mine mounted in a corner it doesn't make much of a difference to me.
(For anyone who has a 3d printer or wants an excuse to get one I'll post a link to the 3D model of the holster this evening)
Semi-back on topic...
Got my Grizzl-e charger installed and ready for my SE delivery in early June! Haven't gotten a chance to test it on a car but at least the LED turns on. All the quotes I got from electricians were too expensive and/or too far in the future so I just did it myself. Running the thick 6/3 cable was a huge pain and it was super hard to actually find a 50A breaker in stock but the rest of the install wasn't bad at all.
I ended up printing myself a custom holster/cable hanger because the one that came with the Grizzl-e felt a bit sloppy to me. The custom one also conveniently mounts to the T-slot I used to mount my bikes on the wall!
I don't really like how far the Grizzl-e sits away from the wall but don't care enough to make a custom "flush" mount.
I've had one of those sorts of failures: I woke up and, while brewing coffee in my kitchen, looked at my MINI app, only to find that the scheduled charging never happened. I went to the garage and discovered I had simply forgotten to plug in upon arrival at home, the night before.I experienced a series of brownouts last night due to extremely high wind. As I left to go to work this morning I found my Grizzl-E EVSE in fault. Unplugged from the SE, toggled the breaker and the Grizzl-E seems back in normal functioning order. But alas, no charge on my SE!
The public fast DC charger I stopped at during my commute was out of service, but I made it to the public Level 2 charger closest to my office (2 miles away) with 15% SoC left. Quite the commute this morning. I guess I wasn't thinking clearly this morning, I should have checked the status of the public charger before going to it. Or even taken my ICE vehicle instead since the SE was "out of fuel". But I love driving it so much I was willing to risk it.
As a bonus experience, I'm riding my bicycle from the office to my car, because I have my SeaSucker Talon stowed in the SE and will just mount the bike to get back to the office. I've read some EV owners stow a foldable electric scooter in their vehicle, maybe I now know why...
