EV Watchdog App
v1.4 now available
Changes for v1.4
  • fixed cost for kwh not parsing
  • fixed max temperature display (was showing min)
  • fixed pack size (39/64kWh) recognition for Kauai/Niro
  • upgraded db to v5
  • added edit cost kwh for trip card
  • added set cost kwh backwards for settings option
  • several other fixes and adjustments
Premium version, all the above plus:
  • added NearBy screen autoupdate option
  • added sync data option
Biggest change is for the premium version where the sync data option is now available.
In order to sync data to the web server do as follows (see attached screens):
1. activate the option in the settings menu,
2. agree data uploading,
3. go to the website sign up page (blue link in the dialog box) and register there providing your NetId code that was copied to the clipboard by the App.
4. verify your email.
dog_net_20-jpg.33457
Then from the App make sure you are connected to a data network and hit the "Sync Now" option in the App's menu to force to send the data on normal usage this is actually not necessary as the App will try to sync several times by itself during operation).
Now log in to the website: https://evwatchdog.net, fill any missing info in your profile, read and agree with the terms and you're in. You should see all your data there plus other interesting graphical and tabular analysis.
FAQ here: EV Watchdog Android monitoring App - FAQ
And be sure to join the dedicated fb group where I share all the developments: Facebook Groups
v1.5 now available
  • Changed capacity calculation for battery card (now uses nominal voltage)
  • Upgraded db to v6
  • Added "Go!" button in charging station details for Maps*
  • Added charging mode
  • Added glide and regenerative braking distance
  • Several fixes and adjustment for charts screen*
  • Several other minor bug fixes and adjustments
* premium version only
Added charging mode which shows remaining time (to 100%), charged kWh and instant charging kW
dog_net_27-jpg.33643
dog_net_28-jpg.33644
New "Go!" button in the charging station details which will open Maps and set destination
dog_net_26-jpg.33642
dog_net_29-jpg.33645
More info on the website:
FAQ: EV Watchdog net: https://evwatchdog.net/help/faq.php
Download: EV Watchdog net: https://evwatchdog.net/app.php
FB group: Facebook Groups: https://www.facebook.com/groups/ev.watchdog
v1.4 now available
Changes for v1.4
  • upgraded db to v5
Neat app, works with my cheap amazon dongle. A couple of observations displayed SOC doesn't seem to always report the vehicle display SOC correctly, particularly if it drops to a 0.5% difference, for example EV watchdog will display 76%, car will display 75% and torque pro 75.5%. Again this is just the displayed SOC. The BMS SOC reporting is accurate, so not a really big deal. The battery inlet temperature on recent trial showed no temperature reading on EV watchdog while torque pro registered -10C. Is there a low temperature cut off in the app? The other thing I noted is that the app does not want to concurrently share the OBD dongle with other apps, i.e. you can't run torque pro at the same time as EV watchdog, you have to completely log out of Torque pro not just close it. This may be a limitation of Android and or the Bluetooth standard.
Overall a very neat app that I see as a decent, easier to use/setup substitute to torque pro. If you already figured out how to run Torque pro I am not sure you will get any more information. The EV watchdogs paid app options, battery alarms are neat but I am unconvinced I really need them.
Hi Apu;
Cheap Amazon dongle - which one?
