engine light-code P1DC7 and P0A7F
alexhol23
hi,
i got 2018 Touring with 88K on it. just got there 2 code on my ODBii reader after the engine light came on. its my 1st real issue with car.
The Honda P1DC7 code is a trouble code related to high voltage battery deterioration. It is a diagnostic trouble code (DTC) stored in the battery condition monitor module (BCM) of Honda hybrid vehicles. is the BCM under 100K mi warranty?
A stored a code P0A7F in your hybrid vehicle (HV), means that the powertrain control module (PCM) has detected an excessive degree of resistance or an insufficient state of charge from the vehicles high-voltage battery pack. This code should be stored only in hybrid vehicles. The HV (nickel metal-hydride) battery is generally composed of eight (1.2-volt) cells which are arranged in series. Twenty-eight of these cells make up the HV battery pack.
Battery pack deterioration and a stored code P0A7F could result in deactivation of the electric propulsion system. The P0A7F should be classified as severe and the conditions which contributed to its storage should be addressed with urgency.
Has anybody had this issue before? going to call the Honda dealership in morning. is any of this might be under 100K warranty?
This is totally wrong for the Clarity... The Clarity has MANY more cells and they are Lithium Ion. They must have re-used the code, but it has a different meaning for the Clarity's hybrid system.
Nonetheless, it seems clear that there is something wrong with your BCM, your battery, or both.
The BCM and the battery should both be covered under the warranty (8 years / 100K) unless you live in California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont, or Washington (in which case it is 10 years / 150K).
I have attached the warranty document for your convenience...
This is a situation where one needs to read the battery capacity. One of the codes may represent that the battery has a de[pleted capacity below the replacement level.
LeoP
According to the manual the P0A7F is set because of the P1DC7 code. There is some diagnostics, like clearing the code and going from 0-30-0mph in EV mode several times. If the code re-sets then it calls for replacing the battery pack.
Out of curiosity, do you charge with a level 1 or level 2 charger? BTW hondapartsnow has the battery pack listed at $4937… still a large purchase.
hi,
What was the outcome for your issue? I just got the same codes on my 2018 Clarity with 82k miles.
We're going through warranty battery replacement right now on our 2018 with those codes, so you may be able to get a new battery through your dealership provided it isn't a 12V throwing weird codes or other issue. Batteries are on backorder, but ours came in in about a month, and is scheduled to go in Thursday. We'll likely see more of these reports as the batteries age out - we consider ourselves fortunate to have it go under warranty and give the car new life. (Dealership quoted over $10K for an out of pocket repair cost)
Good to hear! Ironically, I don’t even charge my car any more because I moved to a city and have to park on the street. But even with that being said, I’ve noticed that the degraded battery does still negativelyaffect the operation of the car in HV mode.
took the car in to my local dealer. they reset the codes and test drove it can didn't come back. They said they need to get a 2nd instance of the codes before they can confirm the battery needs to be replaced.
Ours came back on in a couple drives after the dealer "accidentally" reset them. Pre-conditioning the battery in cold temps and accelerating aggressively might get them to come back faster. Our check engine light and power system warning light went off and back on intermittently over the month we were waiting for our battery. Ours is in the shop now, hoping to get it back tomorrow or Friday.
What’s the latest with your battery replacement. My car had the eagerly awaited 2nd instance of the codes the other day. A second trip to the dealer resulted in them concluding it needs a new pack and getting an approval successfully from Honda management. They haven’t actually ordered it yet so I have no feedback on the anticipated availability date. Ironically, both instances of the codes occurred when my wife was driving the car and she does maybe 5% of the driving of the car.
Perhaps your wife could moonlight as a traveling Clarity battery-breaker :)
We had our new battery installed after waiting about a month. EV range has jumped up to the low 40's (for real, not just guess-o-meter), which for winter temps, snow tires and running the heat is like new. Ask the dealer to put you on priority backorder and start a case with Honda corporate's customer service portal, it may bump you up the list a bit for delivery (and can't hurt in any case).
I'm a cynic at heart, but my advice: Don't accept that dealer BS. Make them document that you requested a warranty replacement within the warranty period, at minimum.
hi,
Is there a place those of us without an ODBii reader will see a warning like this?
Or can someone re-post the thread on using & buying an ODBii? Thanks.
I had these codes on my 2018 touring / 80K miles. They will cause the check engine light to come on at which point you will need to either plug in a reader or take it to a dealer or service shop that can read the codes for you.... Still waiting for my new pack, but its only been a month or so.
Since you aren’t plugging in to charge, at what level of charge do you typically keep the battery when operating the vehicle? The reason for the question is that we know the car operates in a less than desirable manner when the battery gauge shows 2 bars, even with a healthy battery.
