door locks occasionally not working....
Robert_Alabama
Started a few months ago with the driver side rear not locking or unlocking with the fob or switch randomly. Then the issue just went away and over the last couple of months, no issues with it, so I had kind of forgotten about it. This week the passenger front will occasionally not lock or unlock with the fob or switch, then it will randomly start back working again. I can hear no discernable noise or click in the door when it isn't working. What do y'all think? Kind of odd that two of the doors have behaved pretty much the same as they misbehaved and that the misbehavior comes and goes...
Looks like it is highly likely that it is the door lock actuators.... Have to decide if I really want to deal with it on an 8 year old car....
It's interesting the problem is intermittent rather than just failure. The intermittency (is that a word?) makes me wonder if it's loose or over-flexed wiring.
I found this post on this forum:
and this one on another forum:
Both lead me to believe the actuators are going, going, gone....
When our driver's door actuator staring going bad, the door lock/unlock was also initially intermittent. Fortunately, we had the extended Honda warrantee so the fix was at no cost. The dealer gave me the broken actuator. It appears that the motor goes bad. There are quite a few website articles about this and the repairs needed, including replacing the $10 motor.
LeoP
Door lock actuators can be sensitive to volts/amps, and may work intermittently with slight changes that land near that required power threshold. When I put a bed cap on my truck, I wired it's power door lock to the truck's front passenger door -- the cap lock worked every time but the front passenger door only worked intermittently. To fix it, I had to tie the cap's lock to the driver's side rear door -- that shorter distance reduced overall wire resistance, and everything then worked correctly. Unless you've made changes to your door-lock wiring circuit, the most likely culprit is aging actuators that now require a bit more power to work consistently. Do they work intermittently only when the the car is off, but worked consistently when the car is on? If so, the higher voltage when the car is on (i.e., the traction battery is actively charging the 12v battery) might be the reason they work.
