teslarati97
Relative to previous 50/50 RWD ICE vehicles in winter with hilly terrain, I would say the Cooper SE is excellent for traction!
Don't know what I was thinking, my brain and words mismatched. I meant DSC prevents wheel slip, which is why in loose conditions like snow you don't go anywhere no matter how much power you apply. Turning on DTC gives the traction for loose conditions, which is why it displays TRACTION on the instrument cluster.I think you have that a bit backwards... The default DSC traction control allows almost no slip (which is why the traction light is always on, indicating limited power)
no idea. i did a napkin run. it’s about the cost of my insurance after my three tickets incident. About $4k+ CAD a year. Not too bad considering the price of the car.I'd be interested to know how much more expensive insurance will be for the Taycan. Will it be less expensive than for a Porsche 911 Turbo?
You are right. I finally figured out how to completely turn off TC and STC. Feels a lot more connected now.Have you tried DTC or turning off the traction control altogether?
This is a good video from a guy in Canada who likes a challenge, but nearly came unstuck!
I sent him a reply with the info from the Mini handbook... just in caseGood video, but surprised he didn't know how to turn off traction control. That's snow 101 even for ICEs.
Generally I'd go with that, but DSC aggressively prevents wheel slip which is why you can't go anywhere on loose surfaces like snow or gravel. DTC is shown as "TRACTION" on the display, and it's what I use on snowy roads. I can climb snowy hills easily in this mode. My understanding is EDLC (everything turned off) is almost zero traction control and I wouldn't want to use that except in ideal conditions.Sound right?
Sound right?
DSC is not just stability control, it's also the most aggressive mode of traction control and prevents basically any wheel slip.DSC is for cornering dynamics, preventing over/understeer by using the brakes - per the manual.
Correct that forward momentum is optimized but it does that by allowing wheel slip (it will do a slightly limited burnout). This mode does still have stability control using the brakes. The note in the manual about reduced stability is because it allows some wheel slip which will cause understeer that the system can't prevent.DTC is a version of DAC where forward momentum is optimized (no burnout wheel slip heading forward). Turning this off briefly when driving in slush or uncleared snow covered roads will help. - manual
That's interesting. Sounds like the DSC is more aggressive than in BMW's normal offerings. I only drive in DSC off when doing autocross, when I actually notice power limits. What were the road conditions? Cold? Wet? I would consider turning DSC off if it's going to be causing brake use...hate the dust!
Yeah, that doesn't seem like a situation that would warrant aggressive DSC. Do you see a cut in the power-meter, or is this just a seat-of-the-pants sensation? What happens when you push the throttle? Also, any difference in Sport mode?
If you haven't found the BimmerCode threads yet, it'll allow you to make sport mode the default so you won't have to do it manually every time! IMO the throttle response in the other modes is too vague with the giant dead zone for coastingYeah, buddy! Glad to see I won't be alone in Sport only mode!
