Greetings, new member and first post. I just picked up an Iconic SE eBlack a few weeks ago. I ride and needed a solution to carry my bike. I spoke with a sales rep and was told that the hitch that outmotoring sells for an ice cooper S worked for the SE.I don’t think this post goes in the order tracking thread, or delivery experience (in and out in 5 minutes). So I will just stick it here. Sometimes it pays to be lucky. I fully expected to have to special order an SE but after talking to the salesman about what I thought I wanted in colors and trim, the GM swung by and mentioned that they happened to have an Iconic trim on the boat, except for yellow mirror caps and Scissor spoke wheels (was thinking black caps and Rail spoke). Mirror caps can be swapped, was not sure about the Scissor wheels, not seeing them live. But what the heck, a $500 refundable deposit. It arrived at the port by the 17th, arrived at the dealer on the 24th. Picked it up with 10 miles on the odometer and in my driveway on the 26th.
I think the wheels just may be a little bright for the White Silver color, but the rail spoke may have been similar. No rattles, nicely put together.
I do notice the same steering wheel shudder that I noticed on the test drive of another SE weeks ago. A little difficult to repeat reliably as its only noticeable when taking it easy and driving on a slight downslope with just enough throttle to maintain speed or slowing a little and the power within a band of the ready point. There will often be a steering wheel shake for a couple seconds. After I flip from normal to sport under the same condition, if it shudders it will be worse.
Anyway it is a White Silver Iconic trim with the Mini Electric surface and optional roof rails. It did come with rear parking sensors and Hankook Tires. Currently connected to a Grizzl-E EVSE and charging. I hope to have plenty of miles of smiles and enjoying the conversations here.
Now to figure out what to do about carrying a bike, my shoulder had a stop in it that will prevent lifting the bike onto the roof.. shoulder surgery, hack on a hitch, use the truck?
View attachment 12106 View attachment 12107
Yes, it bolts onto the stock mounts (not really, they needed a bit of grinding to enlarge the mounting holes, and two plastic brackets hanging down from another plastic bumper trim needed to be trimmed), but the 1 1/4" receiver didn't work for me, since my current hitch rack is 2".
The as-sold hitch receiver would have also protruded through the painted bumper skin rather than the black fascia. That, and the 1 1/4" receiver were both deal breakers for me.
I needed to decide whether I was going to build one from scratch or modify the one they sell. So, I bought the outmotoring hitch for the ice cooper S, a 2" steel receiver tube that was 6" long, and went over to a friend's house who's quite handy with an arc welder, to modify the hitch as purchased.
I calculated that with a 1/4in steel plate, and the 2" receiver tube welded to that and the 1 1/4" receiver, the 2" receiver would then protrude just under the lip in the lower fascia. We cut out a 1/4" inch steel plate about the length of the 1 1/4" receiver, but a bit narrower and welded it to the bottom of the 1 1/4 receiver to space it downwards. We then tacked the 2" receiver on for a trial fit, and reinstalled the bumper skin loosely. The receiver didn't stick out far enough so we moved it out another 3/4" in. Btw, we drilled the hold for the bike rack security pin prior to welding onto the purchased hitch.
Another quick trial fit, some primer and gloss black paint, some trimming with a small cutting wheel on the lower fascia, and here it is. My bike rack has a wedge on the mounting surface to reduce wobbling of the rack while driving. With that properly secured, the rack is super solid going down the road with my bike on it, and I don't really notice that my bike is hanging off the back.
If you know what you're doing, the tail lights and rear bumper can be off the car inside of 15 mins, it was simple once you figure out that you have to reach inside the rear opening in the tail light cavity and release some tabs. Takes a bit of careful pulling on the rear quarter moldings, but other than that, very straight fwd removal of bumper skin.
I don't have a outside media host, and I don't see where I can post pics. I posted photos at a facebook Mini SE group, here: https://www.facebook.com/groups/463488294398832
