Clarity keeps forgetting settings
ken wells
Twice now our one month old Clarity has changed from auto-lock when out of range back to manual lock mode and also no longer changing the seat position to the memorized setting upon entry. Has anyone else experienced similar memory/setting loss? Granted it's memory is better than mine at my age, but it's still annoying.
Neither key fob changes the seat position? If one works and the other doesn't...
You can press the button on the door to select a stored seat position, then get out and back into the car with the opposite numbered key fob to test each one.
I believe the seat position is stored in the car not the fob as can be proved by the fact that you can set the memory of the seat position without the fob and can call up either position without the fob. All the fob does is tell the car to select the first or second seat position in the car’s memory.
We had a similar problem last month. Seat position memory was lost, and walk-away lock wouldn't work. Not sure what the dealer did, but it's fixed now. I looked at the receipt, but unfortunately, the dealership didn't document what they did (no surprise).
