victor_2019
I noticed an annoying software bug in the clarity PHEV
I keep my car in ECON mode because I want it to remain in EV mode all the time, since my commute is short (10 minutes or so).
and when I start with the car in ECON mode the ICE will remain off all the time.
however:
if I change to normal or sport mode and accelerate hard, the ICE will come on and stay on until the internal temperature is high enough. this is normal.
what is not normal is that after I do this, and I switch back to ECON mode, the ICE keeps switching back on after it turns off. this happens over and over until I turn the car off from the start button and then back on again.
so, to summarize:
car in ECON from start-up: ICE never turns on.
Switch car to normal or sport, accelerate hard: ICE turns on.
Switch car back to ECON.
ICE remains on until temperature is reached, then ICE turns off. so far so good.
however, now, with car in still in ECON mode, ICE will start turning on and off. It turns on when accelerating even though in ECON mode the acceleration needed to trigger ICE turn-on is never reached (I use moderate acceleration here, I don't push pedal past the physical switch point or anywhere close to that).
ICE turns on during acceleration, then off when coasting/slowing down. then on again during accel.
pressing going out of ECON and back into ECON mode does nothing to fix this problem.
if I pull over and turn the car off and on again, the car behavior returns to normal and ICE won't turn on again. I can accelerate as hard as I want, as long as I don't go beyond physical switch, and ICE won't turn on.
however:
so, to summarize:
