SteveEngineer
Thinking seriously of buying a Mustang Mach-e if I can manage to score one after Ford ramps the delivery back up. My question is about the Ford mobile charging adapter that’s included with the car. It clearly comes with interchangeable wall plug cables to support both level 1 and level 2 charging. Plan to drive up to see my family quite a bit and I will need to charge the car at both locations. I have installed 230 volt 50 amp service in garage at home with an electric oven socket which will easily supply the stock 32 amp Ford charger that is included with the car, but the destination only has 230 volt 30 amp service with an arc welder socket in the garage (no neutral) so I would need to charge there a bit slower using only 24 amps (no problem). My question is — does anyone know if a different charging cable is available for the Ford mobile adapter so I can purchase one that I can use with the same Ford mobile charger with the different garage socket and reduced circuit ampacity at the destination if I bring everything that I need to do it with me when I travel?
