I agree with this. IF it is a dedicated circuit, it is in theory easily changeable to a 240v from a 120v. It requires only a change of breaker in the box.
You do not need to pull a third wire, because you are just changing the use of the existing two conductors: you had a 120 V “hot “wire plus a neutral, and are changing to a configuration with two 120 V “hot “wires that are out of phase and therefore make 240 V between them.
This arrangement is quite suitable for a car charger, which only needs 240 V. It is not suitable for certain appliances, such as most dryers in the lake, because those also expect a neutral so that they can separately have 120 V power available to them.
Not an electrician, etc. (though I used to work for one).
P. S. And ONLY an electrician should do this, and make the determination. However, it might be quite cheap compared to running a new wire. The key piece is that the circuit has to have nothing else on it.
