Car has no Power at all - can't start
  • Thread starter Thread starter Tim94549
  • Replies Replies 23
  • Views Views 4K
Glad you figured it out. New cars and esp EVs are always a learning experience.
Interesting flow chart and details. So THAT suggests that a min 25% SOC is required for the Aux Battery Saver 'top off' .
You seem very very knowledgeable about this ... So if I can ask a question, I've been monitoring my 12V after this experience. I have a Battery tester/display plugged into the center 12V plug. I check the Aux voltage without turning the actual car on (push START, no Pedal). It regularly shows 12.5V .. When I run the car, it fluctuates between roughly 13.6V & 15.6V ... What am I seeing when the car is running? And lastly, I'm assuming it's NOT Charging the Aux when running, right?
Thanks
The older Kona had a yellow/orange light indicator on the front of the car. That indicated when it was charging. The newer ones have it on the dash. But a BM2 is still the best as it not only gives you real time info, but also up to 14 days of history.
