ScubaSteve
Here's a post ceramic coating photo. This was not scrubbed, just soapy water and rinse using a hand-held wand. Dried it using a battery powered leaf blower.
One annoyance is when using the volume knob, I tend to hit the haptic buttons for temperature. Other than that, it's an excellent vehicle. The front window coating was worthless and need to use the wipers all the time (only lasted about 2 weeks). The rear window coating does help; the spoiler does clear the lower 3/4 of the rear window, with the section, underneath the spoiler, accumulating most of the dirt. Regardless, a rear wiper sure would've been good since the spoiler won't help unless the car is moving ... Hyundai.
Update on the ceramic coating ...
It was washed by the dealer to place in their showroom. The tech doing the prep work (several washes and clay bar) noticed the entire body has an unidentified haze on the surface of the paint. We don't know where/how the haze came to be - I suspect during shipping, tech suspects the dealer may have had an acid wash done. It had swirls in the paint too from a buffer used in polishing the paint . Causing more work for the tech to remove the haze/swirls; at least he can get rid of both.
He started doing individual body panels for the ceramic coating late today so he's making progress. Should be able to pick it up on Saturday (this being Wednesday). The haze removal delayed the job by a full day (it's a one-person operation). He said I should see a noticeable difference simply due to the haze removal, let alone the ceramic coating being applied.
As a side note, he said the flaps keep opening/closing and a fan running in his heated shop, randomly; that is a known occurrence but unusual none the less. When he's done, I'll take some more photos and post one or two if they show a big difference. I'm more concerned with protecting the paint and having that wiper-less rear window ceramic coated.
I will update this post once it's all done.
