Part of the reason these modes are confusing is that there not 1 but 2 sets of "modes": Driving Preferences and Propulsion Preferences. In both of these "Mode sets" there is something called "Normal" which is the absence of the other options. That is, if you aren't SPORT nor ECON driving mode you are in "Normal driving mode"; and, if you aren't in HV or HV-CHARGE mode you are in "Normal propulsion mode."
The Driving modes indicate driver preference for how the car drives/performs, such as throttle response and climate control intensity.
The Propulsion modes indicate driver preference for how the car provides/manages energy, such as from battery, from gas engine, etc...
Driving modes: [Change the accelerator sensitivity and energy consumption features]
● ECON:
The throttle is least responsive and the climate controls may have reduced cooling performance
The Gas Engine will assist/start with the accelerator about 80% depressed [at the click]
● SPORT:
The throttle is most responsive and the car will maintain the same level of regenerative braking (set by the paddle selectors).
The Gas Engine will assist/start with the accelerator about 33% depressed [halfway to the click]
● NORMAL:
When neither ECON nor SPORT are selected, the car is in Normal Mode. The throttle is
The Gas Engine will assist/start with the accelerator about 50 depressed [about 3/4 to the click].
Propulsion/Power Sources [Change Gas/Battery (energy production) priorities]
● HV [Press HV Button so that HV indicator turns on]:
This is the most similar driving style to a traditional hybrid car.
The Clarity will use the Gas Engine to generate electricity which powers your electric motors and maintains the charge on your High Voltage battery.
This is well suited to high speed highway driving, saving the Clarity’s battery for lower speed city driving.
● HV Charge [Hold HV Button until HV Charge Indicator appears]
This mode will behave like HV mode AND use the Gas Engine to recharge your HV battery to “12 Segments”
● Normal: [Press HV Button so that HV indicator turns off]
When Neither HV or HV Charge modes are selected, the car will prefer All Electric Driving using the electric motor powered by the battery only.
The Gas Engine will only come on in Normal mode if one or more of the following apply:
. You are going uphill or accelerating aggressively.
. The climate control system is in heavy use.
. The Ambient temperature is too hot or too cold.
. The High Voltage Battery state of charge is very low.
. The vehicle is running a system check.
