teslarati97
California is only 45% renewable and 10.9% nuclear to total 55.9% green energy. New York state is 31.8% renewable and 22.6% nuclear for total of 54.4% green energy. Clearly the obvious way to reduce CO2 emissions to produce more green nuclear energy.Sure. But what about California, the epicenter of EV adoption? Here in upstate NY, we have a mix of nuclear, hydro, wind, and a small percentage of solar, natural gas, and coal.
Have you tried driving a Prius Prime lately? The 8.8kWh battery can be fully charged in 5.5 hours at level 1, perfect for charging at the office! I am perplexed why there is such a need to bash the precursor to BEVs.Also, you conveniently ignored the last part of that post. Even in Kentucky, an EV is cleaner than a Prius.
Drive a Prius Prime (gas only) for 15,000 miles compared to a Ford Mustang Mach-E Ext. Range AWD in Kentucky:
Gasoline is about 8,9 kg of CO2/gallon and coal produces 1.13 pounds CO2/kWh, natural gas 7.43 cu. ft/kWh and 0.0551 metric tons CO2/1000 cu. ft
Prius Prime - 15,000 / 54 MPG * 8.9 kg CO2/gal = 2,472 kg CO2 or 5,450 pounds of CO2 in a Prius Prime (gas only)
Mach-E AWD Ext. - 15,000 miles x 37 kWh/100 miles = 5,550kWh x 68.8% (coal) x 1.13 pounds CO2/kWh + 5,550 kWh x 23.4% (nat gas) x 7.43 cu. ft x 0.0551 x 2,204 pounds per metric ton = 5,486 pounds of CO2 in Kentucky for a Mach-E AWD Ext.
Even in Kentucky, a Prius Prime is cleaner than a Mach-E AWD Ext unless you have home solar charging the Mach-E.
