Brake pad replacement
petteyg359
Would like to know if anyone with a 2018 clarity has had to replace the brake pads on it yet, and at what mileage. Mine just hit 69k miles, and there's no odd noises and they still "feel" fine, but I suspect they're probably very close to needing replacement. I am not sure what to look for at the wheel to find out.
If you drive conservatively and use the regen braking consistently by either sport mode or the paddles they can last a very long time. Mine appear to have about 75% of their wear left at 107k miles so they should go about 400k miles (will outlast me). If you don't know how to measure pad thickness just ask at your next oil change they can probably show you how to do it too.
I have 57k on my 2018. Pads still look new. 90% of the braking is regen braking so pads do not see a lot of use except with heavy brake pedal application. Use a small inspection mirror and a flashlight and you should be able to see the pads.
I had to at 70K, brakes were rusting out, and the front pads had about 20-30% left.
