JyChevyVolt
"MemberJoin: Apr 2018Posts: 76Osceola Arkansas
about 1 hour ago · #1
First full charge 3% to 100%
I pulled a crazy stunt the other day, I drove to the nearest ccs fast charger (75 miles from my home) after starting out with an 88% charge (hill top reserve) and commuting to work… I checked the charging station to make sure it was fully operational and then drove around at high speeds to deplete the battery. Even being 100% confident that I could make it back to the charging station, when the last bar started franticly blinking it put range anxiety into overdrive
When I plugged into the charger I had 3% SOC. Charging from 3% to 80% was the cheap part of the charge and the other half (the expensive half) was charging all the way up to 100% in order to get a data log from near zero to full charge on a 350 KW CCS station. That first 46.2 KW cost me the same amount as the 12 KW I gained in the second half of the charge.
Here are some mile stones:
63%, $1 + 47*.30 = $15.10
73%, $1 + 61*.30= $19.30
98%, $1 + 121*.30 = $37.30
Source: https://www.chevybolt.org/forum/90-...how-many-m-kwh-you-getting.html#/topics/29689
- 13% (gain of 10%, 24 miles of EPA range) in 8 minutes.
- 23% (gain of 20%, 48 miles of EPA range) in 15 minutes.
- 33% (gain of 30%, 71 miles of EPA range) in 23 minutes.
- 43% (gain of 40%, 95 miles of EPA range) in 30 minutes.
- 1st step down 55 KW to 40 KW at 49% at 34 min
- 53% (gain of 50%, 119 miles of EPA range) in 38 minutes.
- 63% (gain of 60%, 143 miles of EPA range) in 47 minutes.
- 2nd step down 40 KW to 25 KW at 66% at 50 min
- 73% (gain of 70%, 167 miles of EPA range) in 61 minutes.
- 3rd step down 25KW to 18 KW at 81% at 74 min
- 83% (gain of 80%, 190 miles of EPA range) in 77 minutes.
- 4th step down 18 KW to 11 KW 91% at 95 min
- 93% (gain of 90%, 214 miles of EPA range) in 102 minutes.
- 95% (gain of 92%, 219 miles of EPA range) start of final ramp down 112 min.
- 98% (gain of 95%, 226 miles of EPA range) in 121 minutes."
