I would still like the rate to be advertised on signage, easily visible without the need for an "app", kWh-based or time based to bring parity with gas stations.It will be interesting to see what the rate(s) will be for kWh-based billing.
I agree, but I think plugshare is the best place to post rates. That way you can shop around if you want to.I would still like the rate to be advertised on signage, easily visible without the need for an "app", kWh-based or time based to bring parity with gas stations.
Press release from BC Hydro - 180 kW dual chargers
Now that's more like it, not sure if they will have CCS, NACS and CHAdeMO connectors, or a combination thereof. They are also shared, so a limit of 90 kW if both are used.
They appear to be well marked, so as to avoid confusion if pulling out the handle if another EV is latched onto the other one.
"The first communities expected to receive these units include Tumbler Ridge, Manning Park, Mackenzie and Surrey. BC Hydro aims to start installing these units in late fall 2023 and many of its new locations planned in 2024 will also receive these higher-powered charging units."
Picture thanks to Burnabynow
Thanks...that worked, appreciate the help.I was able to login and add funds through the web. I initially used the page I used to use and I couldn't login. Then I went here: https://electricvehicles.bchydro.co...rs/how-do-i-load-funds-my-bc-hydro-ev-account and used the link under "To load funds through the website" https://evaccount.bchydro.com/ which brings you to a totally different login page. I used that and I was able to login and add funds. With the "upgrade" back whenever it was, I had to change my password. My recollection is that the process wasn't very elegant and had a number of problems until I was able to upgrade.
Congestion fees would be welcome at 80% and above when busy, somewhat similar to Tesla superchargers.That is good. I agree with the idle charges too. I also think there should be a premium rate for charging over 80% when it slows down. There's always that guy who wants to charge to 100% now that we pay by kwh, and he blocks the charging station for a long time while the electrons slow from a torrent to a piddle during the last 20%. Don't be that guy when there are other people waiting.
Wow, what a deal we have here.Pretty reasonable cost of $0.34 per kWh on all level 3 DC chargers (regardless of maximum charging rate and machine capability).
And Quebec's hydro is dirt cheap too!Wow, what a deal we have here.
Check on the Hydro Quebec prices (Electric Circuit) starting April 2, 2024:
Power supplied Battery charge level Price per kWh*
20 kW or more and less than 50 kW N/A $0.53
50 kW or more and less than 90 kW N/A $0.41
90 kW or more and less than 180 kW N/A $0.53
180 kW or more N/A $0.60
Almost double the cost when charging over 180kW compared to BC Hydro
As of May 1st:BC Hydro switching to energy-based cost charging system as of June 1,2024.
Also extended stay (idle fees) will be implemented @ $0.40 per minute - starting 5 minutes after the EV stops charging. This will help improve the process.
