Battery Charger DIY
  • Thread starter Thread starter KalEV
  • Replies Replies 7
  • Views Views 771
KalEV
Hello, new to the forum. I've had my Clarity since 2019 and 120K miles. I can no longer charge by ANY charger either Level 1 or 2, BUT, it does charge if I push the button while driving. Honda says it could be the battery charger and they want $5600. The part is about $2500 online. Has anyone tried to DIY it? If so, how did it go?
That's a pretty hard to justify cost either way. If it were me I would just switch to burning gas. Although I am interested to see if anyone has done this DIY.
I’d recommend that you have the issue properly diagnosed, otherwise, you “could” end up throwing money at parts that don’t need to be replaced.
The Federal Emissions Warranty covers the charger, and many other components, for up to 150,000 miles in some states. We could speculate that you are beyond 150K, since you stated that the car had 120K in 2019, or that you do not reside in a state that carries the 150K warranty. All we know is that you bought the car in 2019 with 120K on the odometer.
As mentioned, the low cost solution is to charge (up to 60%) via HV+ and to learn to live with the inconvenience of that solution.
In the event the charger has failed, a unit could be sourced from a salvage yard, eBay, etc for less than the cost of a new unit from the dealer. Replacing the unit carries some risk, including but not limited to, electrical shock and death. Paying a trained professional to replace the part may be an option to consider.
What state do you live in? You are covered up to 15 years/150K miles in these states:
California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon
Pennsylvania, Rhode Island, Vermont, and Washington
Really cool project, especially the focus on safety and proper voltage control. I happened to check https://casinosanalyzer.com/free-slots-online/Fishing-God / earlier and noticed that, just like DIY electronics, understanding the underlying systems makes everything feel more rewarding.
Thanks for the advice, I will keep it in mind.
I believe the charger is inside the battery case, which is very heavy and requires training to disassemble safely. The warranty or possible good will from Honda are the best bets.
