KentuckyKen
I am in the process of installing a 9.4 kW PV system and thanks to this thread I researched whole house surge protectors. They all pretty much wire in next to your circuit breaker box requiring a hole to be cut in the drywall and a short run of wire through the adjacent stud to the breaker box.weave and rickreagan... can you elaborate on the architecture maybe photos on how/where its connected. Also typical cost to do something like this.
My circuit box is in basement.
Most are in the $100 to 200 range plus installation. I’m bundling mine in with the solar install. My electrician friend said if I cut the hole and drilled the stud so all he has to to was the wiring that he would do it for his service call fee.
I picked the Intermatic Smart Guard IG2240-IMSK because it has user replacable TPMOV modules, so if you get hit with the “big one”, you just replace a module for $40 each instead of the whole unit and an electrician’s bill. A little more upfront at $212 but you save later if it takes one for the team; it’s quick and easy (and cheap) to fix.
Here’s a link to one on Amazon.
https://www.amazon.com/Intermatic-I...etailBullets_secondary_view_div_1537970191493
I love this forum. All y’all have saved me so much money on so many levels. Although here you’re making me spend money, but it will save me in the long run.
