But if LA ones are as slow and unreliable as you say, then it is high time they were upgraded...
Yeah, all they have to do is switch to a fuel that's practical rather than ridiculously impractical and pernicious. The reason those fueling stations are so slow and unreliable is an obvious and predictable result of using H2 as a fuel.
Since we want a renewable fuel to replace fossil fuels, synthetic methane would be a good choice. Since that can be used to replace natural gas with no alteration, there's a ready market for it. And I'd love to see a movement to replace diesel with synthetic methane (or even natural gas) for long-distance trucking, until the BEV tech is up to that challenge!
A highly relevant quote:
I don’t want to turn this into a debate on hydrogen fuel cells, because I just think that they’re extremely silly. There’s multiple rebuttals of it online. It’s just very difficult to make hydrogen and store it and use it in a car. Hydrogen is an energy storage mechanism, it’s not a source of energy. So you have to get that hydrogen from somewhere.
If you get that hydrogen from water, you’re splitting H2O. Electrolysis is extremely inefficient as an energy process. If you took a solar panel and used the energy from that solar panel to just charge a battery pack directly—compared to try to split water, take the hydrogen, dump the oxygen, compress the hydrogen to an extremely high pressure—or liquefy it—and then put it in a car and run a fuel cell... it is about half the efficiency. It’s terrible.
Why would you do that? It makes no sense. Hydrogen has very low density. It’s a pernicious molecule that likes to get all over the place. If you get hydrogen leaks from invisible gas, you can’t even tell that it’s leaking. But then it’s extremely flammable, when it does, and has an invisible flame.
If you’re going to pick an energy storage mechanism, hydrogen is an incredibly dumb one to pick. You should just pick methane. That’s much, much easier. Or propane.
The best case hydrogen fuel cell doesn’t run against the current case batteries. So, then, obviously, it doesn’t make sense. That will become apparent in the next few years. There’s no reason for us to have this debate. I’ve said my piece on this. It will be super-obvious as time goes by.
--Elon Musk, January 13, 2015
One of the ways it's becoming ever more "super-obvious" is the way H2 fueling stations are so often low on fuel or closed, as well as how the number of stations built lags further and further behind the goals announced by the California Fuel Cell Partnership, as the years go by.
