Billcross
After some time to learn, I recommend you to use netflix apk version suitable for android version, if there is a better solution, please comment!
Please let us know if it works,
This post indicates you can set Fake Parking Status to do what you want.Does Honda Hack bypass the requirement that the car be stopped to enter an address into the Honda Navigation system?
I can validate that it does. The basic version would be sufficient, but I went with the pro anyway because of some of the other features...Does Honda Hack bypass the requirement that the car be stopped to enter an address into the Honda Navigation system?
No, there is no change. The only major slowness you would experience from Honda Hack is if you install Google Play Services; then the system slows to a crawl.One of my concerns has been overall degradation in response to all touchscreen inputs with Honda Hack installed. Has anyone noticed a response time change after installing?
I found out in the user manual (page 311) that "remember last screen" only works with the default screen interface design but not with the prettier "alternate mode".For those running HH...
Upon startup, HH automatically dismisses the initial warning banner, and you are left at the HOME screen.
This is OK, but I would prefer to always start out on the built-in navigation MAP screen (or perhaps wherever I left off previously).
There are a couple of features within HH that imply that you could do this:
1. Run an application at startup - This does not work because it only allows you to chose from installed Apps (I have none). The navigation function is apparently not an application per-se and it does not appear on the list.
2. Restore Last Function at startup: This is defaulted to OFF (and it starts up on the HOME screen). If I turn it ON, then it starts up on the AUDIO screen regardless of whether the MAP was on when the vehicle was turned off.
I mentioned this to the HH author and he suggested trying Honda's built-in function - "HOME >> Settings >> System >> remember the last screen”. This did not work either (still starts on the HOME screen).
Anyone have a thought on this?
Hum...I found out in the user manual (page 311) that "remember last screen" only works with the default screen interface design but not with the prettier "alternate mode".
This isn't directly related to your question but this may pique your interest:Hum...
I have never "changed the screen interface design"
Hum...
You may be right, but the way it is worded is a little confusing. I have never "changed the screen interface design", but you may be right that the navigation map may be equivalent to an "alternate mode". Another thing that is not written clearly.
Hey Mr Fixit, the post by Pooky above shows exactly what I was talking about. That is the "alternate screen interface", as opposed to the "default screen interface. It has a more "computerish" like, but in that mode you can't have the "remember last screen" option.
You know, I was also thinking about this just the other day but I haven't bothered much with it. I am not certain if it is possible either.Yep, I get that... My point remains however that I have never changed my interface (it is the default), but the "remember last screen" does NOT work in my case (where I would like the "last screen" to be the MAP in navigation mode... (Touring with built-in navigation).
Yep, I get that... My point remains however that I have never changed my interface (it is still the default), but the "remember last screen" does NOT work in my case (where I would like the "last screen" to be the MAP in navigation mode)... (Touring with built-in navigation).
It seems that the navigation map must fall into the same category as the "alternate screen interface" even though my settings are still the default.
Interesting... Are you also running Honda Hack?Then when I went back and turned on the car, the MAP screen came up!
Whatever the behavior of the vehicle, it is complicated by Honda Hack because it also has startup functions that may or may not interfere with the normal vehicle behavior.
One other thing to be careful of. I have noticed that it takes the vehicle quite a while to shut down completely. If you turn it off, and then turn it back on without waiting maybe 30 seconds (as you might do during these experiments) it will come right back on to where it was and not really boot again. You have to be sure it is 'really' off for an experiment to be valid... The evidence of a true boot is the Honda banner.
