i tried but once the system detect the apk file on USB, the 'Install button' on pop-up is greyed out.Might wanna try to get a apk file on a USB drive and see if you can install it that way....
yeah.. its in 'Settings' --> system -> All --> scroll all the way down and select 'change skin'.
lot more options at your finger tip then the default screen. also the visual is better (IMO)Now I know I can go back I may play with it some more.
Why do you like it better? Are you able to customize what's on that screen and arrangement?
There is a white list file that has approved apks in it. Editing the whitelist and installing apps is 80% of what Honda hack does.i tried but once the system detect the apk file on USB, the 'Install button' on pop-up is greyed out.
Awesome. Are you be able to use Google Maps offline (download maps and store it into the headunit)?UPDATE:
Even though the tablet and Google Maps through Android Auto was working, it was annoying to have to connect via bluetooth every time I got in car.
I decided to try the Honda Hack. Quick and easy and I got Google Maps and Waze installed. I also installed the YouTube app, NetFlix and even MLB.At Bat. Seems to be working well, and this version of Google Maps is much better than what went through Android Auto.
Can you install vlc as well? I wanna see if I can play some Disney for my kid XDUPDATE:
There should be a toggle on top after you enter the developer page, you can turn it off there.Anyone know how to exit developer mode??? That might be the problem?
Get a androidmine works seemlessly and don't need Bluetooth to stream music.... Map talks also don't kill music too!
Go into Honda hack and use fix problems button. Then reboot your head unit.The toggle there doesn’t actually shut off developer mode. It just shuts off the developer options. But it still says I’m a developer.
I might have to do a hard reset. I can’t get Android Auto to work for nothing now.![]()
