Anyone Else's Charger Hang Backwards?
IMG_0127.webp Was thinking of somehow mounting the charger to the wall but the way it hangs when plugged in is backwards... Not sure if this is the intended design or I just got a lemon? Twisting it seems like it'll break it.
Seems a bit odd.
Yes, it’s been noted before. If you use the included bracket it shouldn’t break, but it’s less than ideal. If you mount it horizontally (perpendicular to the and below the receptacle), that will relieve some strain from the twist. Or just leave it like this and try to ignore it — though my mild OCDs would have me up nights knowing it’s just not right.
Ahh ok good to know I didn't get a lemon :)
Mine didn't come with a mounting bracket, would you mind sending a picture of what your bracket looks like? I may have to follow-up with my dealership. thx!
Mine is packed up for shipping, I got a Grizzl-E EVSE for my home. I’ll see if I can dig one up online.
Yes, kind of, but then the output cable goes “up.” While I have no doubt this is just a design oops, the loop idea is that the receptacle is lower than the cable hanger, and the output cable then naturally goes up to it.
View attachment 18668 Was thinking of somehow mounting the charger to the wall but the way it hangs when plugged in is backwards... Not sure if this is the intended design or I just got a lemon? Twisting it seems like it'll break it.
Seems a bit odd.
How about pulling it up and using a cable-tie to tie the input and output cables together? If the input cable isn't long enough for that, maybe tie it to something above the outlet (drill a hole for a screw in the outlet box?). My 2021 SE didn't come with this otherwise wonderful FlexCharger, so I can't try this jury-rigged solution myself.
Edit: If you used a cable-tie to make a loop in the input cable, would that turn the unit around?
I have what must be a very unusual situation (my outlet is outside next to the driveway, and the outlet is low so that the cable isn't about to trip someone), and I have the same problem. The display on the cable is facing the house (and is about a foot off the ground). My solution is to not ever try to look at the display. My phone app probably tells me more information anyway.
Same here. It an engineering issue - the adapter plug needs to be rotated 180 degrees! JuiceBox 40..
I bought a
I bought a bracket for hanging the charger along with the cable (see image below) from my Mini dealer. It was about $42 (U.S.). Model number 61 90 5 A13 A62.
attachment.php
attachment.php
I had heard of this bracket before but never seen it. I designed and 3d printed a bracket similar in function it appears. I made it where it works vertically or horizontally in theory, but really only works mounted vertically. I plan to remove that functionality later but it works well for now and if I ever need to take the charger with me, it's 2 seconds to take it off the wall.
PXL_20221022_230303643.webp PXL_20221021_222209923.webp PXL_20221021_222046450.webp PXL_20221021_222030370.webp
Lol! I paid a local 3D printing shop to make a bracket for me before I found out the '23s shipped with the BMW bracket… and before I decided to get a Grizzl-E EVSE instead.
40121DDC-94DC-49E6-90E8-9A36792F0AD6.webp AE280A47-FF0D-4303-ABFF-2976BDC2C3C6.webp 7C5594E2-C338-45FE-9E1A-F4A44D093B47.webp 285F4DD9-89B1-423C-8091-1767D50FA3AE.webp My ‘23 did not ship with a bracket.
I made a slide-in cleat out of scrap plywood. It’s just an angle-cut piece the size of the charger that fits into a correspondingly cut wall bracket. Installed an outlet so that the wire lined up.
Soon 220v will go in, but just a long run of cable and the big GFCI that code requires is like $500.
Just $500, I was quoted $1550 to run the wire and install outlet rated for 50 amps. The outlet is about 60 feet from the panel.
Still looking for other quotes if anyone has recommendations in the Baltimore area.
