You have once again shown that you are incapable of admitting that you were wrong, even when everyone can see that you were.
How very clever of you to know what everyone else is thinking!
Everyone, How on earth do you know? I'd call that a trifle arrogant, personally.
Mind you, you often tell everyone what I am thinking too. As usual, it is seldom anywhere near the mark.
Here's something that I AM thinking however. Of the four crashes violent enough to result in fatalities, the only one that DIDN'T burst into flames was the one where the vehicle went at speed under a truck, which presumably ripped off the upper part of the car, killing the occupant, but left the battery which is lower down sufficiently undamaged for a blaze not to occur.
If you remember, I calculated the probability that - if battery cars and petrol one are EQUALLY vulnerable to ignition on impact - of three out of four battery cars igniting was on in about 38,000. In other words, though the sample is small, it is looking extremely likely that battery cars are far more likely to end in a fire after a violent crash.
I look forward to your misinterpretation of this, and the construction of a straw man which you will knock down in triumph accompanied by some ridiculous emoticons beloved of the immature.
