Alternatives to OEM tires
  • Thread starter Thread starter Charged_Up
  • Replies Replies 114
  • Views Views 43K
I bought the Michelin cross-climate tires recently for front tires on my 2018 Clarity (not Touring)--my OEMs in rear still have good tread. Went with these because I wasn't happy with traction from the OEMs. As others noted, on wet roads, tires would often spin from a stop and not even with heavy acceleration. The down side: definitely lost mileage. As I changed the tires right around the extreme cold weather we've had in the US Northeast, I'm not able to tease apart cold weather from new tire mileage. But with temps averaging in the 20s F (and many times in teens or lower), I'm only getting about 37miles on a charge. Thought in cold weather I was getting 44-45, which would mean a very significant drop from the tires. But perhaps weather is even colder.
I got the tires (plus a much-needed alignment) from the dealer when they did the fuel pump recall replacement. I don't see why that fix would affect my miles on a charge, but perhaps they messed with something...?
I plan to invest in the Torque (or whatever) software that will give me a reading on battery capacity--I'll review that thread in this forum. Dealer remains unable/unwilling to test battery capacity without charging me some ridiculous amount.
Here's an update on the Nexen N5000 Platinum tires that I installed a year ago -- one of them developed a significant bulge on the sidewall near the bead. While this might have been due to a manufacturing defect, it also could have been caused by hitting a pothole (which are plentiful and deep in my city). In any event, I replaced the tire with another Nexen. Overall, I'm still happy with the price and performance of these tires.
Thanks for sharing. My Nexen's are still fine after over 10,000 miles and comming up on two years soon.
After my Nexen tire was damaged, I debated whether or not to replace both front tires. Ultimately, because the tires were only a year old and had little wear on them, I decided to replace just the damaged tire. Yesterday, the other front tire was badly punctured, so I guess I'll be replacing both front tires after all. On the bright side, it wasn't the new tire that got hit -- and I have an extra 3/8" socket adapter to add to my toolbox!
Due to this flat, I also got the opportunity to use my Spare Tire That Fits! for the first time. I had the car back on the road in about 20 minutes, and can still drive it while I'm waiting for the replacement tire to arrive. For me, that's a much better outcome than having to wait for a tow truck to drag the car to my home and dump it in my driveway. I'll likely get another spare tire for my other Clarity.
I replaced the damaged Nexen tire with a new one yesterday. After driving with the spare tire on the car for a week (local, in-town driving only), I thought I'd share my experiences with it. Overall, the spare worked fine with no major issues. It replaced the front left wheel, and I opted to leave it in that position instead of moving it to the rear axle. Once the spare was on (using the tools/jack that I carry in the trunk), I recalibrated the TPMS and it never triggered a warning after that. This isn't surprising, given that the spare tire's diameter is very close to the stock tire's specification. However, the spare was noticeably louder, less smooth rolling, and affected the steering/handling somewhat (all of which are to be expected). If I ever need to travel long distances with the spare on, I definitely would shift it to a rear-axle position and limit the speed to 50 mph (as specified on the spare). Given those relatively minor limitations, I'm very pleased with how the spare tire performed. IMHO, it definitely was worth the time/cost to get it, and the space lost in the trunk to carry it. BTW, I put a new tire on the spare soon after I purchased it because, for me, carrying a spare with an 18-year-old tire mounted on it doesn't make sense.
What size tire did you get for your spare? Like you I didn't feel comfortable with the older tire on the spare I bought. I didn't find a size available in a new tire that was a perfect match. I settled on a Goodyear 155/80/17. The spare is 1.9% (0.5") taller than the stock tire. Online recommendations are that tires be within 1% of each other when on a drive axle, but I'll probably run it on the front if I have to for a limited time. I suspect there is some give in that 1% recommendation.
I replaced it with the same size tire that came with it: T145/80D17. I think the brand was Falken.
Yes, you found a better choice. It is within the 1% recommendation for matching diameter/circumference. I don't think it is worth it for me to change mine, but glad to know there is a good option out there. Thanks for the info.
If a same diameter spare tire isn't an option, I prefer to have a slightly undersized one versus oversized -- that way, as the car's tire treads gradually wear, they'll narrow the gap with the spare rather than increase it. For example, with your spare, the size gap may start at 1.9% (0.5") taller but could increase to as high as 2.8% (.75") taller by the time your tires are ready for replacement (i.e., down to 2/32 of tread). This assumes that your tires start with 10/32 of tread when new and will lose 8/32 (0.25") by the time you replace them.
After 8-9 months of having the Nexen platinums here are my thoughts…. I originally thought they were quiet but since the weather has warmed up and I am now opening the windows, boy are these much louder than stock Michelins. At up to 30mph the seem fine but at highway speed the are loud with the windows open. Every crack in the road, or RR tracks, is loud. The traction and handling seem good and the ride is ok. My mileage has not really suffered much, maybe a few miles. They were priced right but I don’t think that I would buy them again.
10 months update on the tire. Range did took a hit from high 40s with OE tire to mid and low 40s. Other than that everything else is good , noise , traction... Only managed to drive about 5k miles, now at 44k. Updating it now as I am selling the car. There is likely no further update.
New tires are Goodyear assurance outlast from Walmart. They are affordable, 600 usd every thing included. 80k miles rated. So far I have no complaint coming from 6 year old OE tires….
Here's an update on the Nexen N5000 Platinum tire maufacturers warranty. I picked up a nail on my right rear around 11,000 miles which is not repairable due to its proximity to the sidewall. I brought the car back to Sam's Club where I bought the tires, and they said they would prorate the cost of a new tire based on exisiting tire wear. I checked on the Nexen website and they have a 100% replacement cost road hazard warranty for precisely this circumstance. When I pointed this out the manager at Sam's Club, they said they do not honor the manufacturer's warranty but instead offer thier own road hazard warranty which prorates the cost! I couldn't believe it when I heard it, so I called Nexen, and they concurred that thist is indeed the case, that most dealers do not honor the manufacturers warranty. Instead customers can file a warranty claim themselves on the website! You need to provide some pictures and copies of necessary paperwork, but it didn't take too much time. I expect to be fully reimbursed by Nexen for the full cost of a new tire (less mounting and balancing). Just an FYI for you Nexen 5000 Platinum owners.
30,000 mile update on my $80 Blackhawk tires. They continue to be great, good traction and quiet and very smooth ride; about 4/32" left so I will probably replace them in Spring before the next rain season. Hydroplaning is definitely an issue here with our typical 1 to 3 inch per hour rains so I don't want them to get too smooth. I had a nail in one 10,000 miles ago right at the edge of the tread, went ahead and plugged it on the wheel myself and its been fine. Its position did encourage me to get an aftermarket tire pressure system with sensors on the valve tips, they are only $20-40 and work well; I highly recommend them for this car since we don't have sensors.
Replaced my Yokohama YK740 with same brand "GTX" a few weeks ago. FWIW, the YK740 only lasted about 40k miles, well under their warranty, but they were not noisy, and handled well. New ones feel the same, just a new name.
