Good write up
here and I particularly like this in one of the comments referring to BMW i3 Rex:
"Most PHEVs have 3 fundamental problems. All electric range is the first. As the article outlines, AER of 75 miles or more would significantly cut down on the ICE usage of a PHEV.
Second is an oversized dependence on the ICE. Need heat? Turn on the ICE. Need more power? Turn on the ICE. ICE reliant engineers have a difficult time understanding that the ICE in a PHEV should be strictly a backup system to the electric drivetrain.
Finally, most PHEVs have a crippled charging infrastructure which lacks DCFC. For some reason neither PHEV or BEV designers really figured out that the smaller the battery and the smaller the range, the more important it is to have fast charging capability for range extension.
Only one PHEV almost got it right: the BMW i3 Rex. BMW designed it as a BEV with a serial ICE whose only job was to recharge the battery. The vehicle started with 75 miles of range, ending at over 120 at the end of its run. It had DCFC capability. And the only purpose for the ICE was to recharge the battery. It's only flaw was that the ICE was a bit too crippled in terms of the fact that the gas tank was limited to 2.4G and that the ICE would only come on when the main battery got down to 6%. The latter could be changed with a bit of coding where the ICE could be activated when the battery was under 75% capacity and could run at the same time. This was great for range extension for long trips instead of white knuckling a 5% battery and an empty gas tank.
The concept should be revisited with a larger gas tank and a bit faster DCFC speed than the 50kW the i3 Rex had. A 100 mile AER battery with a 10-15 gallon tank that charges at 100-125 kW in a large SUV/truck package would be close to a perfect combination as a urban/suburban commuter with the ability to carry around larger families or moderate towing on longer trips.
