23' M3Pef HV issue...Need help
23M3P
Ok so bought a wrecked 23' model 3 performance. Replaced the pyro fuse, restraint control module, PCS, HVC, VCfront and lv passthrough at the pack under the seat and got most all errors gone but still no high voltage power(contactors not closing). only errors i have left are
pcs_a042_dcdcenablelinemismatch
pcs_a076_dcdcendessertederr
pmr_a056_canhardwarebusb
gtw_w113_unrecogniozedcanmessage
bms_a071_sw_sm_transcon_not_met
from what it seems there is a miscommunication between two things on the canbus but i cant figure out what that would be as i replaced most main components to no available fix. I will say the pcs was fried with no response and the pyro obviously blown, but toolbox cleared the vcfront as well as its replacement so I am at a loss for words. Anybody have any ideas that may help?
See if you can contact "Rich Rebuilds." He has rebuilt Teslas before and if he doesn't know the answer, he can probably refer you to someone who does.
GOOD LUCK!
