Fast Eddie B
You may recall I’ve been occasionally, but fairly regularly, charging my Clarity using the stock charging cable, but with adapters to allow it to take 220v. I only do it when I can benefit from the roughly doubled charge rate. Absolutely no problems so far doing so.
Yesterday I made a round trip to our GA home, and used my adapter cable to plug into my 50A RV receptacle. I’ve done it maybe a dozen times before to no ill effect. And this time it dutifully charged the Clarity to 44 miles EV range in about 4 hours for the trip back to TN.
But as I unplugged, all was not well. One “hot” prong was literally quite hot - enough to start melting both the plug and the receptacle:
I’m back in TN now, and will inspect the plug connections later. Next trip to GA I’ll inspect and replace the receptacle. I strongly suspect a loose or compromised connection of some sort, maybe due to corrosion or wear. I’ll report back on what I find.
