Firstly, you would have to have paid for the fast-charging capability upgrade on your Bolt (it was a $750 upgrade when I bought my 2017). You can tell if you have the capability to fast charge if there's an orange flap covering your DC port as in this image:
http://www.wind-works.org/cms/uploads/RTEmagicC_Chevy_Bolt_Charge_Port_Snip_01.JPG.jpg
However, there are two types of Tesla charging stations. One is called a destination charger and the other is a supercharger. I assume what you are referring to is a supercharger, as you referred to it as Level 3. In that case, you will not be able to charge at those stations regardless of whether you have the fast charging option or not. Chevy Bolts use a different standard and plug called
CCS or Combo chargers. As of yet, Tesla is not sharing their supercharging network with anyone.
In the event that it is a Tesla destination charger, there is something called a JDapter that converts the Tesla plug into a J-1772 plug. I have no experience with these but you could look into that if it is indeed a destination charger and not a supercharger. To be clear though, this is not Level 3 charging. It would be Level 2.
But basically, you can only fast charge your bolt at a DC Fast Charging station that has a CCS or Combo plug.
Hope that gets you on the right path.
