KiwiME
First check that Aux Battery Saver is checked in the menu options controlled on the steering wheel, sounds like it isn't. Second, once your 12V battery suffers a discharge you may want to purchase and use a proper calcium-compatible charger, otherwise have it professionally charged.
There's no other practical test but you could attach a bluetooth BM-2 monitor, mentioned in various threads.Is there a simple test I can do to check this, other than putting a voltmeter on it every few days?
Yes, but ... from Run mode go into Utility mode from the same dash menus as above. That way the car can be left relatively secure and 12V charging will carry on for the entire duration....some contributors to this thread talk about leaving the car in 'run' mode to charge the 12v battery. What is 'run' mode? Presumably not the one where the little green car is ready to move
