My front 12V accessory outlet went out a few weeks ago when using 12V air compressor to fill winter tire with slow leak from apparent current overload. I then used the Honda supplied tire inflator (which works much better) from rear 12V accessory outlet several times with no issue. This week I foolishly used my old air compressor on rear 12V outlet, and that outlet stopped working after few minutes.
Expecting fuses needed replacing, I replaced both 20A fuses (front #29 rear #10) but both 12V outlets still don't work. I checked the fuses I had removed, and they were still good. Checked back at fuse panel and both circuits are getting 12V when accessory/power is on.
It looks like the 12V accessory outlets have additional overload protection beyond the fuse panel. Perhaps inline fuses or circuit breaker at the 12V accessory outlet. I tried removing the rear outlet but I don't think it will come easily without breaking something. I have seen parts diagram of the front console with 12V outlet but don't have wiring diagram.
https://www.hondapartsnow.com/parts...plugin-clarity-phev-ka-cvt/console-front.html
Anyone have idea about this? Might Honda have 2 level circuit protection on 12V outlets?
