Yellow Light On Dashboard
Discussion in 'Hyundai Ioniq 5' started by BobS, Mar 23, 2022.
Tags:
  1. BobS
    BobS Active Member
    This morning I have a yellow light on the dash board next to the speaker. It was on solid , not blinking. What does fit mean?
  3. BobS
    BobS Active Member
    I'm. thinking that I may have left the car in the accessory mode overnight, and the yellow light warns of that.
  4. insightman
    Does accessory mode run down the 12V battery? Does the Ioniq 5 come with an Owners Manual?
  5. The Yellow light on dash is lit when the 12 Volt battery is being charged from the HV battery. Perfectly normal and a good sign that the I5 is looking after itself. There is a constant drain on the 12 Volt battery to keep everything running/monitored. The drain may be small but it is a drain nevertheless so an occasional charge is needed. Of course leaving the car in accessory mode would be a bigger drain and I'm not actually sure if the maintenance charge would take place or if accessory mode would eventually turn off. I usually just go to ON mode, even if just playing around to assure 12 Volt is maintaining a charge.
    Mike Bearsails, BobS and electriceddy like this.
