Wireless Apple CarPlay
Discussion in 'Clarity' started by Scot Woodyard, Aug 14, 2018.
Tags:
  1. Scot Woodyard
    Scot Woodyard New Member
    Carplay works when I plug my phone in using a cable, but not wirelessly. It appears to be set up correctly - any suggestions?
  2. ClarityDoc
    ClarityDoc Active Member
    Sounds like it's working as described by Honda?
  3. StickWare
    StickWare Active Member
    It doesn’t work wirelessly
  4. amy2421
    amy2421 Active Member
    "They" say there is too much data to transfer wirelessly so it has to be done through the cable.
  5. qtpie
    qtpie Active Member
    You can pair your phone with the head unit via Bluetooth. However, Carplay functionality won't be available via Bluetooth. Carplay requires the phone to be connected to head unit via a cable.
  6. Johnhaydev
    Johnhaydev Active Member
    I believe BMW is one of the few manufacturers starting to offer wireless CarPlay on at least some models
  7. ManKo
    ManKo Member
    Wireless carplay uses Bluetooth only for the initial handshake and then uses WiFi for the connection. The Clarity has WiFi built in, but I highly doubt we will ever see Honda add wireless carplay functionality to our Clarity’s. Heck, they won’t even fix the wireless Pandora.
  8. Scot Woodyard
    ManKo - I believe you nailed the issue. The Clarity does show up when you follow the directions for enabling wireless CarPlay, it just doesn't work after you configure it! Perhaps you have to connect to your phone as a wireless hotspot. Oh well, the cable works - it's just not always convenient.
