Windshield washer nozzle position
Discussion in 'Clarity' started by Raymondca, Jul 14, 2019.
  1. ClarityBill
    ClarityBill Active Member
    I gave up putting RainX on the windshield with my last car: Too much work. I just buy the RainX brand washer fluid, and it seems to work as well.
    We have slush in the winter, so I ended up using about 1 gallon of the stuff on my windshield through the winter. Still has the rain flying off.
    sabasc likes this.
  2. insightman
    Ken, I just couldn't stop myself!
    sabasc, Vic, MPower and 6 others like this.
  3. Paddy
    Paddy Member
    I bought the clean and water repellent 2 in 1. Cleaning is fine. Didn’t see very good water repelling. Maybe 2 in 1 is not as good.
    sabasc likes this.
  4. MajorAward
    MajorAward Active Member
    sabasc likes this.
  5. Mowcowbell
    Mowcowbell Well-Known Member
    You can use Meguiars Quik Wax on those parts you mentioned. I use it on all my exterior glass and painted surfaces as well. Spritz it on, buff it out with a microfiber cloth.
    sabasc likes this.
  6. David Towle
    David Towle Well-Known Member
    Yes I recall the rain droplets to be mesmerizing to watch, not great if the driver loses his concentration on the road!
    sabasc and MPower like this.
  7. MPower
    MPower Well-Known Member
    Thank you @KentuckyKen et al. for your advice. I now feel prepared for my first adventure in car potions. Maybe someday I will actually wash the car (and pigs may also fly)!
    sabasc likes this.
  8. sabasc and MPower like this.
  9. Rick Davis
    Rick Davis New Member
    Reply. My experience also. For me, not enough spray to completely wet the driver side blade; top third stays dry. Many are recommending using Rainx or equivalent. I'm working with Honda CS and two dealers who clearly do NOT state it works adequately and will not commit to solving. Still working with them.
  10. tim
    tim Member
    I finally took my car to the Honda dealer, and the mechanic found that my fluid nozzle was incorrectly positioned. Now the fluid goes to the right places, although the amount of fluid is still not that great. I had assumed that since the nozzles were mounted on the wiper arms that they couldn't be adjusted, but apparently they can be adjusted.
    sabasc, Mmisola and KentuckyKen like this.
  11. Anecdotally, I understand that RainX works very well for antique cars with vertical windshields.
    The curse of modern, sloped windshields is that while gravity pulls the drops down, the wind from driving pushes them up. In a Model T, gravity's gonna win every time.
    sabasc likes this.
  12. MPower
    Thanks for the info. Next time I take the car in, i am going to ask them to check the adjustment on mine.
  13. Sthomasa
    Sthomasa Member
    Had the top of wiper smear and dribble fluid problem. Discovered a button on driver door. Top left, in series of four. At a light push it, when hearing motor stop, take clear plastic container usually located, near parking brake button. Remove top. Reach out window and shake water bottle all over windshield... wiper washer then works well.
    sabasc, MPower and insightman like this.
  14. eneka
    eneka Member
    Took a slow-mo video of the wipers. You can see the top nozzle is a bit oddly positioned.
    This system found on Mercedes and Some Tesla's has the seem same concept, but work much better. They are made by Bosch as well IIRC.
    The model 3 seems to have a similar system as ours
    sabasc and Ray B like this.
  15. I can't remember if I mentioned this before.
    For the Honda cover on the front buy a package of screen protector sheets for phones/tablets. Use a piece of cardboard to make a template the shape of the cover. Cut a bunch of the protectors to that shape. Put one one the cover and when it gets dirty remove it and put on a new one. Should work on the back as well.
    Not something I bother with as rain/snow are rare in Las Vegas.
    Someone, somewhere, mentioned a good wax they use that allows quick removal of bugs, etc.
  16. Two things with the wiper squirting poorly.
    I used a small brad to clear the little openings and it made a big difference. I wonder if junk got in there during shipping?
    Someone mentioned that they can be realigned. Again using a small brad or pin.
  17. Golfdave
    Golfdave New Member
  18. Boston_Pilot
    Boston_Pilot Active Member
    I’d love to see that trick at highway speeds.
  19. fotomoto
    fotomoto Active Member
    I tried conventional spray heads.:eek:
    With additional tubing and hand-made brackets, I mounted them at the outside edge of the hood/cowl pointing back towards the center of the windshield. It worked better than OEM while stationary or at low speeds but the aero’s at highway speeds really altered the spray pattern to be less effective than OEM. :(
    More later.
    David Towle likes this.
