Whether or not to use HV mode on Daily Commute
Discussion in 'Honda' started by Lowell_Greenberg, Apr 7, 2019.
  1. Lowell_Greenberg
    Lowell_Greenberg Active Member
    I have a 44 mile round-trip work commute with extended hilly uphill/down hill sections. On a fully charged battery, I can complete the commute with roughly 10 miles of EV range remaining at the end, using normal mode throughout. The commute is 50% city (where some of the hills occur, usually traffic free) and highway (flat).
    I think my current approach maximizes fuel economy and efficiency, but I am wondering if ending up with 20-25% remaining charge each day is good for the battery longer term.
    I am tempted to engage HV mode, not on the highway (which I would for longer highway trips) but before going up hills and using normal mode when not going up hills. Despite excellent regenerative braking- the car tends to lose more EV miles uphill then it gains going downhill.
    However, for some reason I am reluctant to do this. I could of course use HV mode on the highway- which would conserve charge- but also decrease overall mileage. Of course the same is true using HV mode for up hill.
    What are your thoughts on this? Also, if there is remaining EV charge, is normal mode generally running battery only- except perhaps when AC or heat is running? I am guessing if it is very hot or cold-I will be forced into HV mode during this commute.
  2. Pushmi-Pullyu
    See the forum discussion thread below, which is chock full of actual hard data and much useful advice:
    "Charge Strategy for Max Battery Life"
  3. Lowell_Greenberg
    Thank you. Quoting from one of the responses in that thread:
    "What was enlightening for me was that the charge/discharge cycle itself is actually very benign and doesn't on its own lead to degradation. Cycle count, depth of discharge, and mechanical stress from changes in cell volume are not the root cause of the problem.
    The degradation comes from being at high state of charge, especially in high temperatures."
    So don't routinely floor your vehicle when going up hill (heat), while living in a Palm Spring's summer (heat) or over charge (if the car even allows you to).
    I guess I"m OK :)
  4. Pushmi-Pullyu
    Yeah. I've noticed a pattern of new Clarity PHEV owners posting questions to the forum about the best strategy for maintaining battery life, and I've responded with a description of how to maximize that by minimizing the depth of daily cycling. But stepping back and looking at the larger picture, I think that's a mistake. PHEVs are designed for daily cycling of much of the usable capacity (which is always less than the full capacity of the battery pack), and limit the level of discharge by engaging the ICEngine to keep the battery pack's charge from falling too low.
    Therefore, it's probably a mistake not to use the full EV range available, even if that means running the battery down daily to the point that the ICEngine range extender kicks in.
    After all, most people who buy a PHEV, whether it's a Clarity PHEV or a Volt (sadly now out of production) or even a much shorter EV range Prius Prime... I think those people choose a PHEV because they want to reduce the amount of gasoline they burn by as much as possible. And if that's why you chose to buy the car, then you should focus on how much gas you can save every day, and not worry about how fast the battery is gonna degrade. Likely it won't degrade that fast, and in the meantime you'll probably be saving money -- and almost certainly reducing your carbon footprint -- by using electricity instead of gasoline.
    Now, with a BEV it's different. If you're running a BEV's battery down to the point that it's almost out of "juice" every day, then you're overtaxing the battery pack. Either you bought a BEV with a range too short for your daily needs, or else you're not charging it up sufficiently when you do charge it.
    But PHEVs are not BEVs, and the charging strategy should be different.
  5. PHEV Newbie
    PHEV Newbie Well-Known Member
    If I was in your shoes, I'd charge to 80% and run that down to about 30% at the end of the day and run the engine once in between to make up the difference (on the freeway, where it's most efficient). That way, your gasoline will stay fresh and your engine will stay in good running condition without piling on the miles. People seem to forget that one of the worst things you can do to an ICE is to have it sit idle for long periods and run it only occasionally. Besides, the HV mileage is so excellent that you should feel no guilt for using gasoline. The battery is small so if you intend to keep your car for 10 years or more, you'd be pretty upset if you lose 50% of the range well before that.
  6. TeeVee
    TeeVee New Member
    I have a similar commute and likely will be short of charge in the winter. Wondering about when to engage HV mode too. I wouldn't mind engaging it for a longer period, but it is very noisy, especially HV charge mode. The engine cycles on for only brief periods, like 20 to 30 seconds when I accelerate and revs like crazy as speed is increased. Then it turns off as I maintain speed. Is this how other hybrids work too (cycling on-off several times a minute)? I was surprised that the acceleration has such an effect on the ICE when there is plenty of battery (> 50%). I thought that the battery would be used for acceleration like in EV mode and the ICE will run for a longer period at lower RPM to keep the battery charged. The cycling of the ICE was surprising since others on here have complained about the ICE staying on for 10+ minutes to warm up. The ICE will only stay on for 30 seconds after I turn on HV mode then it cycles multiple times a minute and revs as I accelerate in moderate local traffic.
    Why doesn't HV mode behave like that? The engine is off for extended periods, so it seems like the same amount of energy could be generated by running the ICE longer at lower RPM instead of cycling it on and reving it to power the acceleration. Maybe this is to avoid charging loss by generating electricity directly to the motor.
  7. Pushmi-Pullyu
    Running the motor at lower RPM would almost certainly be less energy efficient. The Honda PHEV is engineered to always run the powertrain at the highest energy efficiency possible, and that means running the ICEngine at its "sweet spot" RPM speed. I know the Chevy Volt was engineered to run the ICEngine unthrottled -- that is, with the throttle wide open -- because that's the most efficient way to run an ICEngine. It wouldn't surprise me at all if the same is true of the ICEngine in the Clarity PHEV.
    I can't speak from personal experience, but a lot of Clarity PHEV drivers posting to this forum report the "angry bees" sound of the ICEngine running at high speed is disconcerting, or perhaps even disturbing. But I submit that's just an emotional reaction from those used to driving gasmobiles. It doesn't necessarily mean Honda did a poor job of engineering. Maybe Clarity PHEV drivers just need to get used to it. However, if the sound really is that loud, then perhaps Honda should have used more sound deadening.
  8. TeeVee
    TeeVee New Member
    If that is the case then how come the engine sound changes as the car is accelerated in both HV and HV charge? When I go from 0 to 35, the ICE will kick in around 10MPH and the engine sound increases as I reach 35 and decreases if I release the gas before hitting 35. Seems like if some RPM like 4000 RPM is optimal then it should jump to that right away. And HV charge should stick to that RPM too to be optimal. Instead what I get in HV charge mode is a higher idle RPM and much louder sound as I accelerate. Maybe the idle RPM is the optimal RPM and the increased sound is to provide extra juice instead of draining the battery during the acceleration. The idle RPM in HV charge is not bad. Would be nice if there was a tach display to quantify the RPM. Does OBD-II provide this on the Clarity?
    Yes, the engineers must have figured out what is best from an efficiency standpoint. And maybe that is to avoid pulling charge from the battery since there is loss when charging it.
  9. Pushmi-Pullyu
    A higher load will cause the sound of an electric motor to change, even if the RPMs don't.
    But I'll note that altho the Volt runs its ICE unthrottled and theoretically at the highest energy efficiency RPM, if you look at the video showing animation of the various driving modes, it shows the RPM increasing a bit when the ICE has heavy demand placed on it. That is, when called upon to simultaneously charge the battery and provide power to the EV motors, it increases its RPM speed a bit under that load.
    Perhaps the Clarity PHEV works the same way. And perhaps the description "most efficient RPM speed" should be thought of as a narrow range of speeds, rather than a single exact speed.
    Hopefully it's clear that I'm making an educated guess here, rather than stating facts. It would be great if we could have a Honda engineer address these questions!
  10. TeeVee
    TeeVee New Member
    Do you mean the ICE here? The electric motor is quiet as a feather (at least in EV mode). My comment is about the ICE (apparently, since EV mode is so quiete) getting lounder, meaning likely the RPM is increasing significantly during acceleration.
  11. Pushmi-Pullyu
    Oh, crud. :rolleyes: Yeah, I meant the sound (engine note) of the ICEngine, not the electric motor. Duh!
    Apologies for creating confusion.
  12. I travel 65 miles each way and have found that using the HV mode on flat sections of the freeway and the electric motor up the hills is the most efficient by far. On downhill sections I never use HV mode, it seemed to regenerate at a slower rate for some reason. Heading to work I get about 140 mpg and heading home uphill I get about 80 mpg. I charge on both ends of my commute. Everyone’s commute is different, try different combinations and see what works best for you.
    Lowell_Greenberg likes this.
  13. KentuckyKen
    If you're ending your drives with 20 to 25 % SOC, then don’t change a thing. That is being very kind to your battery in regards to depth of discharge.
    You can play the don’t charge it up all the way game but I think the BMS keeps a buffer at the top as well as the bottom so IMHO it may gain you much. However to know for sure we’ll have to wait 8 or 10 years and compare notes. I predict it will be a very small difference in capacity/longevity.
    Also if you don’t charge up to 100 % usable SOC, it’s conjectured that you will prevent the BMS from balancing the cells. So if you don’t charge up to 100% usable SOC, it is suggested to occasionally do so to get the benefit of cell balancing.
    Just my 2 cents and you get what you pay fo.
    M.M. and Lowell_Greenberg like this.
  14. KentuckyKen
    My last post #13was supposed to say IMHO not gain you much
    My apologies for poor texting skills
  15. Dante
    Dante Member
    First - YES to more sound-deadening material. I'll give it a 6/10 in road noise dampening (just my opinion - bees or no bees, angry or calm - before anyone gets their feelings hurt) and that's compared to all my previous jalopies, Outback, BMW, and wife's Sonata, and Enclave (this last one is a smooth rolling tank, with amazing silence).
    I have a 110 mile daily commute - hence the Clarity. I charge fully every night and practically deplete the battery every day when I get home. I exclusively drive all "in town" miles in EV, and highway ones (~65) in HV. I've noticed, the times I forgot to plug or whatever, the flat stretches where I'm going 40mph or so without severe slows or stops, the HV mode will work perfect, with amazing gas mileage efficiency, and a pleasant hummm that is unnoticeable. I never use HV charge as that kills gasoline and noise etiquette, and truly is pointless, unless your battery is drained and you're about to undertake a mountain pass.
    As far as cycles and battery health, I always wonder how every incremental regen episode would play into that, if those things would effect the battery life. For that reason alone, I think the battery is immune to incremental, episodic, sporadic, interrupted... and all other variations of how some charge goes into it. Maybe I buy into it bcs it makes me less concerned, but that's what I feel is logical.
    Hope this helps!
  16. Lowell_Greenberg
    Well- since I started the thread... I have a 44 mile commute and typically end the commute with 40%+ charge. I turn on hybrid mode for a brief stretch and refill gas every two months or more- except for long trips where more gas is needed. I charge to 100% on the assumption that a PHEV has a top end reserve of at least 10-15%. Also the owners manual recommends a full charge.
  17. LegoZ
    LegoZ Active Member
    I say go gas-less, the kindness you are giving to your battery will be repaid by its failure outside of the warranty period. If you are unable to make your full commute under battery is HV mode during the hottest period of the day to reduce engine warm up times and achieve higher MPG. I would make sure the engine goes through a full warm up period to reduce condensation in the oil and fuel wash. Slightly expanding on the I would do that on the interstate for the least amount of time outside of warm up period and then go EV only to let everything cool off on the remaining way home.
  18. 2002
    2002 Well-Known Member
    I agree, although I think we are in the minority. My goal is to use as much electricity possible, I thought that was the point. It's not that I don't care about my battery, it's that I am not convinced that driving electric as much as possible will shorten battery life by enough to make it worth burning gasoline when you don't need to. From what I have read during my Prius days heat and age are the main killers of hybrid batteries and those people routinely go 150,000 or more on their batteries. Now those were NiMh batteries until around 2016, Lithium-ion is different and we don't have as much long term experience but I am still not sure we need to burn gasoline to preserve our batteries.
    The manual says charge to 100%, and says nothing about avoiding 0 EV range. I think that's because there is plenty of buffer on top and bottom. Estimates by the experts here are that only 12 kWh of our 17 kWh battery is actually used. We know that 0 EV miles is not the bottom of the battery, not only that it is not the bottom of the usable range, if you look at the app 0 EV is about 10% SOC, that's because 0-10% SOC is used for hybrid mode, the system tries to keep it around 10% in HV mode but allows it to dip down below that temporarily. The most you can deplete the battery is to sit in a parking lot with AC running and it will drain to close to 0% then start ICE. Maybe not a good idea to do that very often, although if the system thinks it's okay and allows it to drop to 0% before starting ICE maybe it's not a not a problem. People in Prius would sleep in their cars with AC running, no one ever proved that wears out the battery prematurely. Again that was with NiMh. But still 0% SOC is probably way above reserve capacity and going down to 0 EV is 10% above that so I am not worried about it.
    I charge until full and drive EV only on drives less than EV range. For drives where I know I will use HV I of course plan for HV on highway etc. But then I try and reach 0 EV around three or more miles from home so that ICE comes on while I am driving around 45 mph and I drive the last few miles in HV. When I reach my neighborhood the speeds slow to 25 mph or less and ICE shuts off and by watching the power meter I can drive EV for the remaining mile through my neighborhood without ICE coming back on. When I reach my house I am at about 8% SOC and then I fill up to 100% ready for the next go around.
  19. Lowell_Greenberg
    In my case, I might use a tank of gas (7 gallons) every 4 months or so. If employing hybrid mode for very short periods to maintain an electric reserve of 30%-40% is needed- I will do it. In addition, over night charge times on 120V are reduced.
    For those that drive much more and/or drive with a heavy foot- and decide to drain to 0%- so be it. But the bottom line for me is maximizing efficiency and conserving battery life. It is a balance, not a science.
    Let's face it a PHEV is not a BEV. A 200 mile range BEV that uses 25% of its fully charged range daily, and is recharged to 80%- will have a battery that lasts longer than a PHEV that uses 100% of its range daily and is charged to 100% every day- even factoring in high and low end reserve. Batteries have a finite number of charge cycles.
  20. 2002
    Of course balance and science are not always mutually exclusive (not that you were saying they are). I think most Clarity owners who are making up their own guidelines to extend battery life are simply attempting to balance unknowns. I am not saying they are wrong, in fact they may turn out to be right. I can't say 100% for sure that several years from now I may be wishing I had burned a little more gas and used a bit less electricity. But to me it's an unknown, and not nearly enough data for me to burn even a few gallons of gas that I don't have to. I realize your point of view is that burning a few gallons of gas is a small price to pay as a type of insurance just in case. I suppose it's similar to the debate about extended warranties, or high or low deductibles on insurance. No answer is right, each person does what they feel most comfortable doing. That is until the data eventually comes in, then it will become less opinion based.
    If you need to. That's what is unknown.
    Unknown how much longer it will last. Yes there is science, we know how batteries operate, some very general non-specific predictions can be made, but lacking specifics of buffer reserves as well as lack of long term test data for the Clarity battery, it is difficult even for a qualified expert to make reliable predictions, otherwise we would have had some already. Hopefully at some point we will start getting some educated guidelines with real numbers from qualified analysis, then we can make the type of balance decisions that I prefer to make. Even then what we will probably get are odds, meaning a specific charging strategy will not necessarily lead to longer life or early failure, just an increased chance of that outcome. How much it increases deceases the chances is what I want to know. In the meantime I will continue to follow the manufacturers guidelines which don't seem to prohibit me or even caution me from using as much electricity as I can.
